BE1 Vs BE3
Results 1 to 16 of 16
Thread: BE1 Vs BE3
    1000+ Posts Poo-Go's Avatar
    Sep 2003
    1,420
    BE1 Vs BE3
    Hello all,
    I am looking at buying a 405Mi16, and have seen references to BE1 and BE3 gearboxes. Can anyone please advise on what the differences (if any) are between these other than the shift pattern? What are the pros and cons, and which should I be looking for?
    JG.
    Care factor = -273.15șC
    Fellow Frogger! Justin B's Avatar
    Aug 2003
    Lugarno, Sydney
    236
    I have a BE1 in my 205 GTI.. and it's a bloody close ratio gearbox for a road car.... the reverse being next to 1st gear doesn't really worry me...
    The only thing you ahve to worry about (I think that this is for all BE1's) is that the filler hole is higher then the level of oil that is recommended for the box. So, make sure that your mechanic knows that it only needs 2 litres...
    i.e the box takes 2 litres of 75w/90 when I filled mine up, it didn't overflow at all...not even close to the hole. The previous mechinic MUST of filled it to the filler hole (as per 99% of gearboxes in this world) because when I emptied the box, about 4 litres poured out....
    I'm sure others will weigh in with data for you to decide.
    Justin
    LookingforMi16:
    Hello all,
    JG.
    Pugsley The 1987 205 GTi Peugeot
    Feb 2001
    493
    oh i HATE the reverse being next to first gear, especially when the 205 seat is pushed up so your hand hits the chair when putting it in reverse!! the number of times i thought i was in reverse but was in first!!! eek!
    nearly hit a car parking in my first week of ownership!!
    but i guess you get used to it
    7,483
    In Mi16's, there is no difference in ratios between BE1 and BE3, only the way you select reverse.
    Aussie 205 GTi's differ:
    BE1 - lower first, 3.9:1 diff
    BE3 - higher first, 3.6:1 diff
    Fellow Frogger! two-oh-philic's Avatar
    Feb 2003
    Glen Waverley, Melbourne
    419
    I don't know that that is entirely right PeterT. As uncomfortable as I feel saying this (a feeling that won't go away until you shut me down with your wisdom), I have the '90 (no p/s) GTi with the BE3 gearbox. Doesn't that mean i have the earlier diff?
    205 GTi (S2 ) rolled
    '96 306XR "Sex" Black
    Moderator Alan S's Avatar
    Queensland, Australia
    8,923
    PeterT:
    Peter T,
    I just had a nasty thought; as there is presently a thread going re; organising LSDs to suit BE1 & BE3 transmissions, are we likely to strike a problem if some are for BX/Mi16 whilst others are for 205s
    Alan S cry whistle
    Feb 2003
    419
    Since we are kind of on the topic, i have a drive shaft seal leak. Says seal needs replacing. What would one of these cost? Would it be hard to replace. I can't be f*cked going to the mechanic again just to pay out another $500.
    NSW
    1,063
    or if you have a 1.6 GTi like me then you have the BE1 box with 4.06 diff ratio. head_ban
    12,266
    Pugsly:
    perfect for motokhanas though
    right next to each other
    just have to remember lift to reverse
    the GTi-6 has the lever as well for reverse even though it is near 6th gear which i would prefer if it was up near 1st
    just think there are a lot of jap cars you have to push the lever down to get reverse
    i prefer the lift up rather than a push down system
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    7,483
    Ah, yes. I forgot the S2 205 GTi. I did say Aussie GTi's Darren.
    S1 BE1 - 3.25:1 1st, 3.94:1 diff
    S2 BE3 - 3.25:1 1st, 3.94:1 diff
    S3 BE3 - 2.92:1 1st, 3.69:1 diff
    Alan,
    I can't answer your question. All I know is that the Quaife fits either, but the ZF needs a bit of work to fit a BE3. I suggest asking Wuillemins, as they are currently a ZF.
    <small>[ 11 September 2003, 07:26 PM: Message edited by: PeterT ]</small>
    8,923
    two-oh-philic:
    Most of these seals aren't all that dear or hard to replace.
    Drive shaft out & are replaced from the outside. The seals have a plastic (white or red) protector ring that fits just inside the face of the seal so as to give some protection to the seal lip on reassembly.
    Word to the wise though; be sure to drain the gearbox BEFORE you start & fill with new oil upon completion. Most seem to wait until they have a bath in gear oil halfway through & then try to guess how much oil came out. mallet
    Cost is approx $12 for seal & about teh same for oil.
    Alan S cheers!
    Feb 2003
    419
    Thanks alan,
    Any idea of difficulty level for a guy who's only ever done an oil change... once.
    8,923
    two-oh-philic:
    Thanks alan,
    Under those circumstances, I don't think I'd try it alone if you know what I mean. cry
    It's a simple DIY for anyone used to DIYing. I had one fitted to one of my cars when I sold it & was too busy to do it myself. Guy threw it up on a hoist, did the job, changed the gear oil and charged me $45 labour so it's not a big job if you have a workshop & know what you're doing...looks more involved than it is to the untrained eye though, so watch they don't try to make it look like something major just to work the account up deal
    Alan S 2_cents
    Lilydale, Melbourne
    2,095
    PeterT:
    Are you sure about that? I remember reading in Wheels an article on the Mi16x4... the writer commented that the car had an updated gearbox, with reverse opposite 5th instead of beside 1st, and it also had a slightly lower 1st gear ratio to compensate for the extra weight of the 4x4 version. This may have been only for the 4x4s, but maybe not.
    John
    John W
    1974 Peugeot 504 TI
    - now on the road
    7,483
    That's correct with the Mi16x4. They have the 3.25 1st, rather than the 2.92, but as we were talking about Aus. delivered Mi16's I didn't think it was worth mentioning. Owen W. has one, and the larger gap between 1st and 2nd is a real pain.
    Feb 2003
    419
    Yeah that's what i have too. It really is a pain. Someone here mentioned that it was particularly bad in hill climbs, and not having done a "hill climb" but having climbed a hill i can only agree. Even if you aren't racing you need to rev 1st to 4k minumum to put the revs in the right spot in 2nd. ACtually i'm dissapointed to know it, coz i always thought i had the perfect combination 205 with the late gearbox and early diff. I wonder if you could get the better gear out of an old 405.
