504 rear callipers...can't turn piston
    Bungendore, NSW
    89
    Default 504 rear callipers...can't turn piston
    Has anyone got any hints or tips for pushing in the rear calliper piston on a peugeot 504? I understand you need to turn it 45 degree before trying to push the piston in, when fitting new disc pads, but I can't turn it at all.
    Suggestions, anyone?
    1000+ Posts Peter C's Avatar
    SWOTR
    3,747
    I've never had that problem. They can be fairly hard to rotate, though. I usually use a large suitably sized screwdriver placed in one side of the slot which gives enough leverage.
    159
    When I did mine I had a piece of steel that fitted into the slot (8mm from memory)that I could attach a spanner to . Never had a problem in rotating the piston this way . Once the piston is back don't forget to return the slot to the original position
    Bungendore, NSW
    89
    Thanks. Will have another crack at it...
    Northern NSW
    1,103
    https://www.ebay.com.au/itm/Brake-Pa....c100677.m4598
    There are cheaper ones too and you can use them on many cars.
    Oct 2017
    hawthorn melbourne
    110
    I have always used a screwdriver on its side to rotate it .Also it is a good idea to attach a tube to the bleed screw and open it when pushing the pisten in to avoid the reservoir at the front from overflowing.
