Boot slam panel 306
    Jan 2019
    New Zealand
    34
    Default Boot slam panel 306
    Hey guys, unfortunately I've had my 306 xsi roll down my driveway and meet the front corner of a deceased 1.8 306, unfortunately keeping the corpse mint and damaging my rear bumper, boot and slam panel (panel between the rear lights & the badges). Fortunately despite the boot floor being a bit bent at the end the car itself came off fine and passed a warrant of fitness with flying colours, I'll get that straightened out. I have another 306 with a suitable rear bumper and panel, I can figure out the rear bumper easy enough. However how do you remove the slam panel if there even is an easy way to do it? Could be a silly question overall and I may just have to get that done professionally as well, however anything to save and use what i''ve got.
    Car in question is a 1998 peugeot 306 xsi.
    Feb 2001
    Romsey, Victoria, Australia
    4,887
    Go and see a panel beater. There a welded in panel so expensive to change, often cheaper to have yours repaired.
    David Cavanagh
    03 9338 8191 or 03 93354008
    34 KING St
    AIRPORT WEST
    VIC 3042
    [email protected]
    1,766
    Same happened to my 205 with a concrete pole, panel beater for sure, its still there 20 years later.
    307 HDi wagon
    407 HDi wagon
    Jan 2019
    New Zealand
    34
    I have the panels available and access to a welder. apart from the obvious welds on the face etc is the rest relatively easy once cut? But baring in mind it could be a messy pain in the ass I'll probably go pro to save the abuse I'll hurl at it working on it. However i can most probably at least remove and get the new panel in place and just get someone more steady to weld it :'D
