In car display temperature indicator gone crazy
Results 1 to 21 of 21
Like Tree8Likes
  • 4 Post By dmccurtayne
  • 1 Post By sfrawley
  • 1 Post By dmccurtayne
  • 1 Post By BarryC
  • 1 Post By BarryC
Thread: In car display temperature indicator gone crazy
    Fellow Frogger! dhaw's Avatar
    Feb 2005
    SYDNEY
    539
    Default In car display temperature indicator gone crazy
    Any modern Peugeot car owners experience this fault and any ideas? My 2008 on a 30 degree day randomly decides its 7 degrees outside. It eventually displays the correct temp but I wonder if it has any effect on my climate control. The A/C does not seem as icey when its playing up. I'd say 80% of the time its fine but at least once a day it chucks a wobbly. Even seen 1 degree and ice warnings..... Restarting the car does not correct it.
    Previously 404 1969, 505, 504 1977, 405 MI16 1991, 205SI ,306GTI6 1997
    Currently 306GTI6 1999 and 2008 Active 2013
    Jul 2013
    Newcastle/ central coast
    2,222
    Yep common problem you can replace the sensor in the mirror and it fixes it.
    4008
    Gone but not forgotten C5 x7 3008 206 GTI 180 306 XR SED 405 MI16 x2 xzara VTS 406 SV 206 XT Berlingo 2011 (best car ever) 306 HDI 307 XSE HDI touring
    Fix it right the first time
    COL, Kenfuego, 207cc Sport and 1 others like this.
    Garage C5 X7 4008
    Fellow Frogger! sfrawley's Avatar
    Feb 2001
    Goolwa SA
    341
    On my 406 the wiring plug connecting the mirror to the vehicle was not making full contact, resulting in funny temps being displayed.
    505604 likes this.
    Stephen
    '03 P406 HDI
    '16 Renault Master
    Feb 2005
    SYDNEY
    539
    Good tip... what would one describe this part as to Dapco? Thanx!
    Jul 2013
    2,222
    You don’t, buy genuine .
    6445 F9
    4008
    207cc Sport likes this.
    Garage C5 X7 4008
    1,784
    Same part on the 306? Here's hoping!
    Sent from my Mi 9 Lite using aussiefrogs mobile app
    307 HDi wagon
    407 HDi wagon
    Feb 2005
    SYDNEY
    539
    Thanks Dapco sells orginal parts I thought?
    Jun 2004
    171
    Good to know that I'm not the only person in the universe with that same fault. Two year old car after 40,000 untroubled Ks decided to do the same thing. It's at the therapist tomorrow. I have just today posted this issue myself - 2008 (2017 1.2 turbo)
    Musing - does this sensor affect the operation of the A/C on Auto? on Manual?
    6,668
    The therapist, or the rapist?
    2003 PEUGEOT 206 GTi
    Jun 2004
    171
    I’m usually fairly mechanically sensitive, so I’m using a therapist...........
    Jun 2004
    171
    My 2008 1.2 turbo had the same issue. To cut a long story short, the dealer updated the electronics and the satnav. (I hadn’t had these done since new, since I get my maintenance done locally), and they also cleaned and degreased the connector in the door. They suggested to me that the electronic update fixed it, I’m pretty sure that they cleaned connector fixed it, judging from my own diagnosis of the error characteristics. I suspect you have the same problem - the sensor is working but the connector is faulty/not contacting fully. Everything works now, anyway.
    BTW the sensor in the door connects to the aircon software when it’s on auto, and unless the sensor is working properly the AUTO setting in the aircon will misbehave/not work. However if you put the aircon on manual by setting numbers on the centre console, this will allow the aircon work, even if the outside sensor is faulty.
    Feb 2005
    SYDNEY
    539
    Quote Originally Posted by BarryC View Post
    Good advice Barry. You say the sensor in the DOOR? Please explain? Where is the outside temp sensor? Mirror? My Aircocn does not work at all when the temp drops below zero! Thanks!
    Jun 2004
    171
    Sorry, the sensor is in the external mirror ON the door. And I have no real idea where this connector is, except that it is somewhere in the door. They fixed it, anyway, by disconnecting it, cleaning and putting some kind of conductive(?) grease in it, then reassembly. My own diagnosis is that the sensor in the external door mirror was never fully faulty/not working as they never got any fault codes for the sensor itself (which would presumably be if it failed fully?). Its low temperature readings I would put down to poor connection/high resistance at the connector itself. I’m happy for any auto electrician out there to contradict me at any time. Cheers.
    dhaw likes this.
    Feb 2005
    SYDNEY
    539
    I just googled and found this. Going to get my Mech to do this at sevice soon and I don't have contact cleaner. Quote..."i just had this dumb problems fix for good, for months even after i change the sensor at the mirror the problems of erractic temperture keeps coming back. today my mech took the bunch of socket out between door and the car body spray some contact cleaner and blow off any access with the pressure blower for abt 15 sec ......wah lah all back to normal , this require some additional hands as the door is quite heavy."
    Jun 2004
    171
    Found this exact google myself and was interested what the Peugeot gurus at the workshop would do. Obviously they know about the issue in 2008s maybe it also applies to other recent Peugeot models as well.
    QUOTE=dhaw;1642364]I just googled and found this. Going to get my Mech to do this at sevice soon and I don't have contact cleaner. Quote..."i just had this dumb problems fix for good, for months even after i change the sensor at the mirror the problems of erractic temperture keeps coming back. today my mech took the bunch of socket out between door and the car body spray some contact cleaner and blow off any access with the pressure blower for abt 15 sec ......wah lah all back to normal , this require some additional hands as the door is quite heavy."[/QUOTE]
    dhaw likes this.
    Feb 2005
    SYDNEY
    539
    update after 48 hrs of fiddling and the temperature is reading fine. I took the back off the review mirror and fiddled with the connector. The two sets of wires are joined at a plug which I seperated and replugged a few times.... seems the issue is with the pins in the plug. Will have to see if the fix is perminent
    Fellow Frogger! 207cc Sport's Avatar
    Apr 2016
    Gold Coast Hinterland
    378
    Thanks for the tips dmccurtayne. You dude, you.
    The French Tart has always shown three deg. more. The RCZ is spot on.
    The French Tart… 207cc Sport THP150 and now a RCZ Mk2 THP200
    1000+ Posts driven's Avatar
    Apr 2005
    1,547
    Don't need aircond in France, but this will not be case with Climate Change
    1000+ Posts Kim Luck's Avatar
    Melbourne, Aus.
    18,384
    Feb 2005
    SYDNEY
    539
    Bug came back and dealer is replacing the temp sensor under warrantee. Of course no part in the country even tho its fitted to every new pug sold...sigh
    Fellow Frogger! 505604's Avatar
    Junee, NSW
    821
    Quote Originally Posted by dhaw View Post
    Isn’t that why there are no parts in the country? The available stock was used on replacing the faulty original equipment.
    (Honestly, I’m not usually so cynical about Peugeot quality! Honest.)
    Current cars: Peugeot 307 HDi Touring; Peugeot 306 Cabriolet; Peugeot 406 HDi, Peugeot 505 Familiale
    Previous cars: 1965 Peugeot 404; 1972 Renault 16TS; 1970 Peugeot 504 1800; 1978 Peugeot 504 GL; 1976 Peugeot 504 LTI;
    1984 Peugeot 505 Familiale; 1982 Peugeot 604 (converted to TD) 1999 Peugeot 306 Cabriolet (better car than the 2002 model we replaced it with)
