308 DW10BTED4 FAP Timing belt Change
    Ric
    Ric is offline
    Dec 2019
    South Australia
    2
    Default 308 DW10BTED4 FAP Timing belt Change
    G'day, So I jumped in and started the timing belt change. All good so far except for the crankshaft belt drive cog seems to have a much larger keyway width than the width of the key. Is this normal for this Engine? I have worked on cars for yonks and I have never seen such a disparity between a keyway and a key before.
    Jul 2013
    Newcastle/ central coast
    2,125
    Totally normal when you tension the belt it will centralise to the correct position Iíve been a psa tech for over 20 years
    4008
    Gone but not forgotten C5 x7 3008 206 GTI 180 306 XR SED 405 MI16 x2 xzara VTS 406 SV 206 XT Berlingo 2011 (best car ever) 306 HDI 307 XSE HDI touring
    Fix it right the first time
    Garage C5 X7 4008
    Ric
    Ric is offline
    Dec 2019
    South Australia
    2
    OK, cheers. I have been working on cars and aircraft for going on 40 years and I have never come across a keyway/key clearance this big before. Then again, this is my first European car.
    Jul 2013
    2,125
    Yeah they do it to help get correct tension on the belt
    4008
    Garage C5 X7 4008
