308 with P0016 error after timing chain replaced
Results 1 to 12 of 12
    Jan 2019
    Auckland
    10
    Default 308 with P0016 error after timing chain replaced
    Hi all, I need some help at what to look at for possible fault.
    I have replaced the timing chain and everything else associated with it.
    Engine is from 308 2008 EP6DT
    The engine oil is replaced at the same time.
    The fault disappears after the engine has warmed up and temp is at 90 degrees.
    And I do heave a problem with the scanner where canít recognise the ECU.
    Any help would be greatly appreciated
    Jul 2013
    Newcastle/ central coast
    2,125
    How did you set the timing
    4008
    Gone but not forgotten C5 x7 3008 206 GTI 180 306 XR SED 405 MI16 x2 xzara VTS 406 SV 206 XT Berlingo 2011 (best car ever) 306 HDI 307 XSE HDI touring
    Fix it right the first time
    Garage C5 X7 4008
    1000+ Posts Peter C's Avatar
    SWOTR
    3,657
    You could write my knowledge of this this sort of fault on the back of a postage stamp but Google says "synchronisation fault between the camshaft and crankshaft". Are you sure any sensors are plugged back in correctly?
    Jan 2019
    Auckland
    10
    Quote Originally Posted by dmccurtayne View Post
    4008
    I shouldíve been clear,
    I had the chain replaced by a friend that works in a mini garage, will have to check with him regarding the timing.
    Do you have an idea what we should look at?
    Jan 2019
    Auckland
    10
    Quote Originally Posted by Peter C View Post
    As far as I know, everything is plugged back in. I will need to go through and check all the sensors.
    Jan 2019
    Auckland
    10
    Hi again,
    So I measured some parameters and something looks bit odd, the engine was warm and check engine light was off
    But I noticed some of the measured values were quite different to the value should be,
    Does that mean that my timing is not quite right
    Jul 2013
    2,125
    A turbo doesnít have exhaust vvt control you need a correct base line first what the vin
    4008
    Garage C5 X7 4008
    Jan 2019
    Auckland
    10
    4008
    Hi dmccurtayne,
    My vin is VF34C5FTF55280392
    Jul 2013
    2,125
    You need to select the correct car in diagbox or force it to maybe even call it a ds3. But in saying that the timing is out so needs to be checked again.
    Making sure the intake hub locks and the correct pin is used on the flywheel
    4008
    Garage C5 X7 4008
    Jan 2019
    Auckland
    10
    4008
    Yeah was selected at the correct car model, I have problem with the diagbox not recognising the ECU. And most likely will need to check the timing again. How much is involved in checking the timing h labour wise).
    cheers
    Jul 2013
    2,125
    Itís not bringing up the correct system so might need to select a cit as I said who ever did your chain should fix this. It only takes less than an hour to check the timing. Iíve been a tech on these for over 20 years
    4008
    Garage C5 X7 4008
    Jan 2019
    Auckland
    10
    4008
    Thanks, will talk to the guy to check the timing
