Conrod bearings - mis-stamped
Results 1 to 15 of 15
Like Tree10Likes
  • 1 Post By kelpiebat
  • 2 Post By PeterT
  • 1 Post By schlitzaugen
  • 1 Post By Stuey
  • 2 Post By schlitzaugen
  • 1 Post By Mike Tippett
  • 2 Post By PeterT
Thread: Conrod bearings - mis-stamped
    Jun 2018
    99
    Default Conrod bearings - mis-stamped
    Hey Guys!
    Bad news  Had the crank shaft freshly ground for the Conrod bearings we had been sent. Unfortunately, although the Conrod Bearings were stamped with measurement, when we went to fit, was wrong. We must have misunderstood the marking of .3 (as shown on bearing) to be 0.30ths rather than 0.3mm.
    We were so close yet so far, almost was in tears after waiting 1.5 years for this engine. Now need to source correct bearings of 0.0030THS (0.0762MM). Could anybody help or know where I can source within Australia? Really don't want to source parts from France. Otherwise will grind crank big ends down to .8 (as I found we do have .8 bearings).
    A sad day,
    Thanks in advance guys,
    James
    Jan 2014
    Coffs Harbour, NSW Australia
    334
    Isn't there an old saying that goes ; never ASSUME, it makes an ASS of U and ME. Or the carpenter's ; measure twice and cut once !
    James Gelido likes this.
    Jun 2018
    99
    Quote Originally Posted by kelpiebat View Post
    Couldn't agree more mate. Rookie mistake.
    7,487
    What engine? I doubt you’ll find a 0.003” undersize bearing for anything. At least you can grind the crank down further. The correct method is to fit the bearings (no crank), measure the hole, add the clearance, then get the crank ground to match.
    James Gelido and driven like this.
    9,050
    Quote Originally Posted by James Gelido View Post
    Hey Guys!
    A sad day,
    James
    Good machine shops ask you to give them the block, bearings and rods with bearings before they embark on grinding your crank because they do as Peter says. They measure stuff and then grind to fit. I suggest you take all that with you to the shop next time even if they didn't ask for it. Or change shops to one where they ask for it without you prompting them.
    One shop where I had some work done discovered there was a slight misalignment in the main bearings' tunnel in the block so they recommended a line bore as well. And no, they didn't upsell me. I checked the tunnel before approving the work and they were right.
    Not all shops are equal.
    ACHTUNG ALLES LOOKENPEEPERS
    Jun 2018
    99
    403 engine. Thats what I thought, not likely. I will have to bite the bullet and grind the crank once again. Won't take much.
    Jun 2018
    99
    Jun 2018
    99
    Thanks for that. I did give them everything; block, conrod bearings, mains, and rod. Practically whole bottom end. Funny enough, the guy said 'don't assume anything' before grinding but still managed to assume that.3 stamp meant .30ths not .3mm. To their defense, they did an excellent job on the head! The issue can be rectified, just frustrating. One small/BIG mistake.
    6,531
    It's marked in either inches or millimetres, and if it was assumed to be inches, .3 is close to 1/3", which is clearly not going to be right.
    2003 PEUGEOT 206 GTi
    9,050
    I still don't understand they would they think it was in inches? It's a french car.
    Mike Tippett and James Gelido like this.
    1000+ Posts Mike Tippett's Avatar
    Jan 2002
    Vancouver Island, Canada
    1,759
    Something like this happened to me in 1987 with a 404 KF2 engine. The machine shop said it had been ground to 0.3 mm but I didn't check with Plastigage during assembly. Started her up - good at first then oil light started to flicker....and after 5 minutes it shredded the bearings and the crank was destroyed. Guy had probably done 1 mm or something crazy. It was BAD!
    I had a second crank and that one was done properly and the Plastigage verified it was good and it went well. Still have that crank as a spare. It was from a ZF car so I had to get the pilot shaft bearing pressed into the end first.
    1966 Peugeot 404 Coupé Injection post-restoration reassembly underway!
    Register your 404: https://recensement.leclub404.com/submit.php
    7,487
    Clearly their fault then. They should be happy to have the opportunity to correct their mistake.
    jo proffi and James Gelido like this.
    Jun 2018
    99
    Quote Originally Posted by Mike Tippett View Post
    Unbelievable! What a pain. 1 step forwards, 2 steps backwards. Did the guy resolve the issue or provide any compensation? Thankfully the engineer did a trial fit for ours and saw the movement and notified me. It can be such a morale destroyer.
    Have to keep pressing forwards though!
    Jun 2018
    99
    Just old school. Everything is inches and assumed because it was an older car, was inches. Who knows ....
    Jan 2002
    1,759
    The second crank was reground for "free" but I got no compensation for the ruined crank. But the fault was partly mine for not plastigaging it.
