S1 205 GTi upgrades - Page 2
Page 2 of 2 First 12
Results 26 to 34 of 34
Like Tree11Likes
Thread: S1 205 GTi upgrades
  1. #26
    9,049
    Powder coating is impervious to aggressive cleaning agents you will need to use later on to get road grime and shit off the wheels, not that I ever wash mine. That was my reason. It's been now seven years and the wheels scrub up like new if you can be bothered.
    ACHTUNG ALLES LOOKENPEEPERS
  2. #27
    Nov 2019
    17
    Very excited about my new exhaust! Car sounds amazing! Definitely needs some fine tuning and the next job is the dyno, but sounds awesome. Check out the pics - https://photos.app.goo.gl/qanou6dwtchNXZqV6
  3. #28
    6,529
    Is that a Magnaflow cat?
    2003 PEUGEOT 206 GTi
  4. #29
    Nov 2019
    17
    I believe so. Certainly a high flow cat, not sure if it is a magnaflow specifically. I'll post a vid. so you can hear the sound in the near future.
  5. #30
    Nov 2019
    17
    Not the best recordings but enough do give an idea of the sound - https://photos.app.goo.gl/qanou6dwtchNXZqV6
  6. #31
    Nov 2019
    17
    DynoFlywheel 3-12-19.pdf
    DynoWheels 3-12-19.pdf
    Had the car on the dyno this morning. 145.8HP at the flywheel, 119.3HP at the wheels. Fuel/air mix is a little all over the place so am considering an after market ECU and maybe replace the air flow meter with a MAP sensor. What ECU and MAP sensor should I get? I imagine after that I could look at Cam upgrade, but even just an ECU upgrade should enable some power gains. Any ideas how much? Thanks. Oh here is some vid of the car on the dyno - https://photos.app.goo.gl/qanou6dwtchNXZqV6
    CEyssens likes this.
  7. #32
    1000+ Posts cam85's Avatar
    Nov 2003
    Bondi
    3,373
    Your looking at 3-5k to do it properly including a stage 1 cam from Peter T. Maybe less if you can do the work yourself.
    Theres probably Megasquirt etc also at the cheaper end.
    94 205 Gti Classic #9
    91 205 Si
    87 205 GTi Race Car
  8. #33
    7,487
    119hp @ the wheels is actually very good for a standard DFW Mi16. They normally pull around low 80s kW @ the wheels and the D6C version around 90.
    BIGRR likes this.
  9. #34
    Oct 2003
    624
    Quote Originally Posted by ROK205 View Post
    If you want the engine to run as close to factory or better then you need an ECU that has a high enough spec that it has closed loop idle control. Any ECU that doesn't is more basic than the standard ECU and they don't hold idle when cold nor drive as well in carparks or at intersections.
    Closed loop wideband O2 is highly recommended to target AFRs for fuel economy and safety under wide open throttle.
    I would also recommend changing the TPS from switch type to a potentiometer type so the car can be tuned off TPS with MAP correction. You can leave the factory TPS completely out of the equation and run the MAP as the only load reference but will likely drive similar to the standard airflow meter with possible hesitations.
    Here's a quick list of suitable ECUs and components with prices
    ECU - closed loop idle control & wideband O2 capability
    MoTeC M84 - $1925
    Haltech Elite 750 $1495
    Adaptronic M1200 - $990
    EMS EM70 - $1170
    Wideband O2
    MoTeC & EMS Built in ($0)
    Haltech WB1 - $400
    Adaptronic - $270
    Wiring loom
    Motec - $400
    Haltech - $200 if bought with ECU or $400 separate
    Adaptronic - $100
    EMS - $???
    ICV - You already have a good Bosch idle control valve, which is suitable and any of these ECUs can control it.
    TPS - You should be able to find a suitable potentiometer TPS, probably Bosch, that will bolt on to the Mi16 throttle body - $150 with connector
    MAP Delco 1 bar sensor & connector (external) - $120 (for MoTeC, others have internal MAP but can run external it you choose. No risk of pinching vaccum lines through the engine bay, firewall, under dash, etc).
    Ignition System - You can use the standard distributor, coil & ignition module.
    Relays x3 (ECU, Ign, Inj) - $70 with holders
    Connectors..........all new, fit new pins to current connectors or cut & solder old plugs complete......depends what quality of fit and reliability you want.
    Tune - $800-$1100
    Also, don't get the impression that all these ECUs are equal in quality & functionality with price differences because of the brand name. They are very much "what you get is what you pay for".
