Peugeot 406 hdi no low beam RH head light
Results 1 to 2 of 2
    Aug 2019
    Wollongong
    28
    Default Peugeot 406 hdi no low beam RH head light
    Hi all,
    I'm new to the Peugeot Forum, having been active only in the Citroen forum up to now.
    I have a problem with the low beam function on my Peugeot 406 hdi 2003 model. It is not a globe fault because I have tried a new one and it didn't work either, and also the high beam does work. So the problem must be either fuse or relay, am I right? And where could I locate the relays, would anyone be able to tell me?
    Would there be a separate relay for each side? Because the LH low beam works fine.
    Thanks for any help
    Anthony
    Nov 2003
    51
    I had this issue on a D8. It turned out to be a faulty earth return from the headlight. I installed a new earth from ythe headlight connector.
    Garry
