Peugeot 308 automatic transmission problems
    Jun 2019
    BALLARAT
    3
    Default Peugeot 308 automatic transmission problems
    Iíve recently purchased a 2009 Peugeot 308 with a Ď20TS30í (AL4) 4-speed auto in it, the vehicle has done 85,000km & has full service history through a Peugeot dealer.
    Unfortunately I purchased it from a private seller & didnít bother to get a mechanical inspection (silly me!) & it has developed some transmission issues.
    I would just like some suggestions on which way to go with it.
    Here are the symptoms
    1/. Firstly when itís cold you select drive & it starts to go then jerks, then goes again.
    2/. Also while itís cold, you moderately accelerate and when it changes from 1st to 2nd gear it stumbles badly (a couple of bang sounds) & then decides to take off again, very disconcerting, especially in traffic!
    3/. When coasting from 80kph back to 60kph and then applying a small amount of throttle is will sometimes free-rev as if itís in neutral.
    4/. The transmission feels as if itís slipping badly when it changes into each next gear & after a few seconds it feels as if it hooks-up & you get positive drive.
    5/. When applying full throttle while driving the gearbox kicks down engine revs hard & it wonít shift to the next gear & sometimes feels as if there is no drive & then a massive shudder/jolt (feels like the engine is about to fall out) & it then puts a fault on the dash (gearbox faulty) & goes into limp mode. I have been able to overcome this by disconnecting the battery for s little while.
    Iím weighing up to get another low km 2nd hand transmission from a wrecker (approx $1000) & fit it, but Iím worried I might end up with the same issue with another box, even though it will have a conditional 3-month warranty.
    Or am I better to get the auto reconditioned? Iím unsure on what the costs are for this?
    Any suggestions on which way to go with this one?
    Jul 2013
    Newcastle/ central coast
    1,675
    Need to get some codes out of it so you know what is failing
    Garage C5 X7 3008 XTE
    Fix it right the first time
    Jun 2019
    BALLARAT
    3
    Iíve had this into my mechanic who is pretty good with these cars. He had a code-U0404
    Which he traced to a shifter issue, he replaced the shifter but unfortunately the problems still persist.
    Jun 2019
    BALLARAT
    3
    Would anyone be able to give me a good contact in Melbourne or country vic area for Peugeot transmission repair/replacement?
    Jun 2004
    142
    Have a look at the sticky posts re Peugeot mechanics at the top of this web page
    Jan 2014
    Coffs Harbour, NSW Australia
    301
    If you google up french transtech you will discover several threads about the AL4 and fellow aussiefrogger frenchtranstech. Last I knew he was running his own successful auto box shop in Melbourne, and considers the AL4 to be a good, but misunderstood auto transmission. Besides that it is a very good idea to ignore the B S about the 'sealed for life' and change the oil with an oil of same specifications.
