407 HDI Fuel Pump Relaylocation.
Results 1 to 3 of 3
    Mar 2011
    Linton.Victoria.
    1,189
    Default 407 HDI Fuel Pump Relaylocation.
    Looking for same.Spent much time surfing the net to find.....BUT THE SURF.....IS OUT...DONE HEAPS OF BELLY WHACKERS ....TOO MUCH GRAVEL RASH.
    Would truly appreciate a solution.
    Jul 2013
    Newcastle/ central coast
    1,651
    The 2.0 hdi doesn’t have a fuel pump relay and a 2.7 relay is in the engine fuse box not technically serviceable
    Garage C5 X7 3008 XTE
    Fix it right the first time
    Mar 2011
    Linton.Victoria.
    1,189
    Yep.Thanks worked that out. I had replaced fuel filter...Whoever had not done so for some time...or got some dodgy fuel. What was happening was there was air in the line between filter and pump.I rearranged that line as it was higher than the filter[??????????] pumped up manually..still no joy. Removed upline connector,pumped the bellows,got flow..away she went. WHAT WERE THEY ...NOT...THINKING.
