Check my 207 Timing chain with EP6 1.6 NA engine
Results 1 to 9 of 9
    Tadpole CC207's Avatar
    Oct 2017
    Kingsgrove Sydney
    24
    Default Check my 207 Timing chain with EP6 1.6 NA engine
    Hey guys,
    I am going to change my valve cover gasket in the next few days. This is due to excess of burning oil, like 400ml in 400kms. I could not find any symptoms for that, so I am going to give the gasket a try.
    (The vehicle is Peugeot 207 with 1.6 NA EP6 engine.)
    Since the engine will be open, I want to check my timing chain as well.
    I wonder if there's any way to check it?
    Thank you for any replies.
    Really appreciate it!
    James
    1000+ Posts driven's Avatar
    Apr 2005
    1,386
    Can you see an actual leak from the gasket?
    If not may have more serious issues
    8,503
    Have you checked the oil arrestor valve in the cover?
    Oct 2017
    Kingsgrove Sydney
    24
    yeah I can see a little bit of oil around the valve cover.
    Since the car is not generating any weird smoke, it's really hard to find out why.
    thanks.
    9,621
    It's more likely that the cover itself is leaking oil from the vent holes at the belt/chain end than the gasket leaking. The cover can split internally and it incorporates oil vapour recovery parts with a diaphragm that can fail. In that case, you change the complete cover, which comes with new seals.
    The chain stretch is officially checked with a dummy/test tensioner. The measurement is compared to a reference and the factory advises to change the chain and associated parts if it exceeds 69mm. Otherwise, the position of the camshafts at TDC may give you a fair idea as they are supposed to make 90 degrees. If they don't, the chain is possibly stretched or maybe the sprockets have turned a little on the cams. The sprocket bolts are critical items and single use only. There is also a timing tool in two pieces that fit over each cam and should meet in the middle if the timing is correct. You may see that illustrated.
    Jul 2013
    Newcastle/ central coast
    1,651
    Is there pressure or vacuum when taking the oil cap off?
    Garage C5 X7 3008 XTE
    Fix it right the first time
    Fellow Frogger! 207cc Sport's Avatar
    Apr 2016
    Gold Coast Hinterland
    314
    If your engine has done 100,000 kilometres, time for a timing chain replace. Good for accurate engine timing.
    The French Tart… 207cc Sport THP150 and now a RCZ Mk2 THP200
    Apr 2016
    314
    Quote Originally Posted by dmccurtayne View Post
    Tell me more Bro . . . which indicates what?
    8,503
    He's talking about crankcase pressures, and ventilation.
