Disc brake piston tool
Results 1 to 7 of 7
    Perth Western Australia
    2,659
    Default Disc brake piston tool
    Anyone out there have the measurements of the Peugeot tool required to rotate the rear disc piston [504]?
    I made one years ago, loaned it out to a friend years ago, funny, it was never returned. [Lesson * 2]
    The tool allowed for the correct amount to rotate piston [45 deg] without guesswork.
    I think the tool dimensions were shown in a 504 manual?
    SWOTR
    3,435
    I've always just used a largish screwdriver of the right size. Can slip a bit but works well.
    2,659
    Thanks Peter,
    I knew someone out there would be brandishing their large screwdriver.
    Oh, I can't get the charcoal for my forge so it rules out fettling one .
    Oct 2017
    hawthorn melbourne
    73
    I always use a flat screw driver too .I don't know what size but is one I use most often as a screwdriver
    1000+ Posts driven's Avatar
    Apr 2005
    1,386
    Screwdrivers, the Bush Mechanics first tool of choice
    1000+ Posts Beano's Avatar
    2,987
    There is a bit of leeway in the 45 degrees, so special tool not that necessary..
    In the 1980s, I found that the perfect width was my points file, but I couldn't always put that much pressure on it.
    And the small vise grips....
    149
    I had a piece of 8mm suare tool steel to fit the slot . T I then could fit a spanner to it and rotate easily
