How to set points vacuum advance cam in distributor
Results 1 to 21 of 21
Like Tree9Likes
  • 1 Post By leregulage
  • 1 Post By Kim Luck
  • 1 Post By Artificer
  • 1 Post By PeterT
  • 2 Post By Wildebeest
  • 1 Post By bob
Thread: How to set points vacuum advance cam in distributor
    Fellow Frogger! leregulage's Avatar
    The hills of Virginia
    136
    Default How to set points vacuum advance cam in distributor
    On a ducellier distributor(working on a 404 sedan here-but applies to all makes with the same setup). When a new set of points are installed, should they line up perfectly- with the engine off?
    This has a vacuum advance-with that turnable cam/ against the rod of the advance cam. I'm thinking to just give it a few notches, until they line up straight.
    Am I wrong on this?
    1000+ Posts driven's Avatar
    Apr 2005
    1,392
    Why change a setting, replace points and check dwell and timing off you go?
    However, get one of these and tune using laptop.
    https://www.123ignitionshop.com/gb/4...as-distributor
    136
    Seems the new points are a bit longer or shorter than the ones it came with( this is a china copy dizzy for a 504- can be found on ebay for very little).
    8,775
    That turntable thingie is there to compensate for low octane petrol, which may cause pinging. Your points should be set so you get a spark at TDC (static), then timing light with vacuum disconnected, then connect the vacuum and drive and only then use the cam if you hear any suspect noises.
    ACHTUNG ALLES LOOKENPEEPERS
    1000+ Posts Beano's Avatar
    2,992
    One half of the points is stationary, and the other moves in and out against it. However the movable one also moves back and forth, rubbing against the fixed one powered by the vacuum. This is how they are self-cleaning.
    Therefore the movable one starts at one end and is sucked towards the other end by the vacuum advance.
    Then eventually....after some time.... an oblong-shaped depression is created in the fixed point.
    So you should set it so that the circle of the movable point is completely within the circle of the fixed point, but to one extreme.....giving it some room to move.
    Never push on the rod going to the vacuum diaphragm....you can rupture the diaphragm that way. Only ever suck on the tube to test how far across the points move.
    6,248
    Beano is spot on, they deliberately don't line up. On points without this system, you get that little pointy bit deposited on one contact.
    2003 PEUGEOT 206 GTi
    136
    Quote Originally Posted by Beano View Post
    Therefore the movable one starts at one end and moves towards the other end, eventually....after some time.... creating an oblong-shaped depression in the fixed point.
    Thanks for that, it is exactly what I'm looking for.
    Beano likes this.
    2,992
    Good to know I made a difference to someone's life.
    If the car ever runs rough because the points have got clagged up, naturally the first suspect is the vacuum advance. To test, just take off the distributor cap, unplug the vacuum tube from the inlet manifold and and suck on it. The movable point will move.
    Vacuum advances aren't getting any younger.
    I'd recommend an electronic distributor....it was such a relief when I fitted one to my 504. Bloody points cause the timing to go out slowly but surely, though the Ducellier are by far the best distributors.
    But the advance curve may be different if you get one from a 505. You could always get one of those aftermarket ones you fit to the existing dizzie......
    6,248
    Yeah, my vaccum capsule required replacement on my R12 and I just a few weeks ago rebuilt a Mitsubishi Triton carb which also needed a new one. It makes a big difference too.
    1000+ Posts Kim Luck's Avatar
    Melbourne, Aus.
    17,683
    Kenfuego likes this.
    Member Artificer's Avatar
    Mar 2018
    Robina
    97
    You might get some value from this as this type kit will fit your distributor:
    Electronic ignition R16 TS Ducellier
    FIX for ELECTRONIC IGNITION KIT that FITS MOST BUT NOT ALL DUCELLIER DISTRIBUTORS:
    136
    Haven't checked the dwell, it runs fine for now. This 404 came with a non- vac distributor, so the china copy one is quite the improvement. I'll be going to electronic ignition soon. I use one off Ebay(accuspark/hotspark), they seem to do a good job. Used a few of their modules through the years.
    Really hard to find good 505 electric dizzys over here. So the aftermarket is a close second.
    https://www.ebay.com/itm/Electronic-...frcectupt=true
    Wildebeest likes this.
    Mar 2018
    Robina
    97
    That is exactly the same kit as I purchased from the UK.
    Perth Western Australia
    2,660
    Artificer,
    Have had one of these fitted to my 504 for about 3 years now. Perfect starting hot and cold. Instantaneous starts from dead cold or if standing for a day or more.
    Have misplaced the UK address of supplier, anyone ?
    Mar 2018
    Robina
    97
    Some mis-info on this thread about point burning & deposits from one point to the other. This is generally caused by incorrect condenser.
    UK source but there is also an eBay source in OZ.
    https://simonbbc.com/
    7,415
    My preferred method for setting timing with points ignition is this:
    1. Assuming new points, set gap with feeler gauges etc.
    2. Set engine at idle advance point. eg 10 deg BTDC.
    3. Connect a multimeter between points and earth.
    4. Loosen distributor and rotate until the points just open. ie no connectivity. Fine tune several times, until you're sure you have that exact sweet spot.
    This method is very accurate and most useful when the engine is out of the car etc. and you want it to fire first turn.
    COL likes this.
    COL
    COL is online now
    A110 COL's Avatar
    Van Diemen's Land
    3,933
    That is the method I use when I have built a fresh engine. It has never failed.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    2,992
    Quote Originally Posted by Artificer View Post
    True...usually condensor.... but I was only saying that if the vacuum advance is not working properly, that will also stuff up the points.
    6,248
    My understanding is that with a good condenser it just happens more slowly. Unless those new condensers I bought for my Cooper S back in the day were shite.
    2,660
    Method used to set timing.
    Locate timing mark on pulley. Loosen distributor. Car radio on, slightly off channel. Volume up. Ign on, now rotate dist* until static "click" is heard.
    *Rotate dist until it aligns with timing mark. Whew !
    PeterT and COL like this.
    bob
    bob is offline
    May 2001
    Skipton
    2,329
    G'day,
    there is an insidious fault with old dizzys with action plates, the moving plate attached to the vac advance module. Ancient dizzys had a proper earthing strap from this plate to the dizzy body, more modern penny pinching versions did away with this strap. Result - devious misfiring due to faulty earthing via dirty sliding contacts.
    cheers,
    Bob
