504 steering rack rebuild - help needed
Results 1 to 12 of 12
  • 1 Post By seasink
Thread: 504 steering rack rebuild - help needed
    Fellow Frogger! Pug72's Avatar
    Feb 2013
    288
    Default 504 steering rack rebuild - help needed
    Hi all
    Some more work on the 504
    The steering rack has had play in it for a long time. I recently replaced the tie rods ends on both sides, the flector, the LH rack end bush (that is outside the steering boot) plus the nylon bush that is at the end of where the steering column enters the steering rack.
    I obtained a steering rack kit and another rack end bush.
    The steering rack kit contains a circlip, 2 seals, a flat washer and a nylon bush.
    I am lead to believe that by having the steering on full lock (turning right), I can remove the LH steering boot, remove the circlip, remove the washer and seals and I can then replace the nylon bush.
    However I am unable to remove the circlip. It is fouling on the steering shaft, ie there is not enough room to compress the circlip and remove it with the steering shaft there. Can the LH steering shaft be removed/unscrewed?
    Secondly I am also lead to believe that there is rack end bush inside the RH steering boot. Is this the case?
    SWOTR
    3,442
    Yes, there is a rack eye bush at the right end of the rack. I think it's the same size as the left hand outer bush.
    It's a very long time since I did a steering rack but to change the left rack inner bush you have to remove the tie rod arm from the end of the rack first. You also have to turn the steering to full lock to the LEFT, not the right, i.e. as if you were turning a left hand corner. Of course, then remove the boot. I don't recall having trouble with that circlip. Good circlip pliers?
    Others will be sure to add as necessary.
    Feb 2013
    288
    Thanks Peter
    I currently have the steering turned full lock to the right, as if I am turning a right hand corner. I am not sure how to remove the steering boot due to the large flat washer on the rack end. see pic
    I see there is also a large nut, so I am assuming something comes apart there, but I have only tried gently as the steering arm seems to twist/flex.
    all advice much appreciated!
    PS...my circlip pliers are well used so maybe investing in a new pair will make the job easier.
    SWOTR
    3,442
    You mIght need to apply a bit of force to unscrew the disc and eyelet. Shouldnt require lots of force though.
    Fellow Frogger! Rally's Avatar
    Pearl Beach NSW
    525
    Its been a long time since I have needed to replace the rack end bush , but I seem to recall that a removal of the rack is required .
    That means remove complete rack from car . remove tin plate cover under pinion , undo nut reveled , remove piion , remove rack and replace rack end bush.
    Peugeot 504 Rally car V6
    Peugeot 504 LTI
    Peugeot 504 Ti
    Citroen SM
    Citroen Light 15
    Peugeot 406 SV 5 speed
    Citroen DS23 EFi Safari
    Toyota Land Criuser V8 Super charged ( to tow the rally car )
    Rally with www.AMSAG.com.au
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    3,933
    I'm not a Peugeot 504 expert but in your pic it looks very similar to a Renault r12.
    On the Renault R12 that nut that you see is a lock nut which is 36mm across the flats. I use a 36mm open ended spanner to undo that locknut.
    If you are worried about twisting the rack use a large shifter to hold the rack end eyelet or put a suitable sized bar through where the bolt goes that holds on the tack arm.
    When that large nut is loose you will be able to unscrew the eyelet.
    Remember also you will need a wheel alignment when you have assembled it all back together.
    Hope this helps
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    9,109
    Quote Originally Posted by Rally View Post
    No need, unless it is a PAS rack? Full LH lock then use a small screwdriver to prise out the plastic bush, Circlip is the easy bit, new circlip pliers needed I would say.
    Feb 2013
    288
    Right, so I just had the steering lock the wrong way.
    I will get new circlip pliers before I attack this again.
    Meanwhile I changed the RH rack end bush. It was shagged!
    No power steering in this vehicle.
    SWOTR
    3,442
    Yep, that's what they usually look like this far down the track.
    I had a very old pair of Sidchrome circlip pliers and the tips had rounded off over the years which caused them to slip off. A bit of gentle grinding of the tips had them square again and usable. This would only work with non-stepped tips.
    By the way, I have a feeling that the lock nut abutting the large disc thing on the other end of the rack is actually part of the disc, and not separate.
    When installing the new plastic sleeve/bush you need to take a bit of care as, being plastic, it is easily damaged.
    Feb 2013
    288
    Thanks Peter
    I have a feeling that I may need to use a little bit of heat to undo the large nut. I have tried a few times today and given that the nut is only thin, i came close to slipping and the last thing I want to do is damage the nut. I will be replacing the boot as well, which I don't have so need to order that too.
    I too have had to grind the end of my circlip pliers a few times. A good excuse to visit Trade Tools
    8,532
    Is this helpful-
    Doush_504 likes this.
    Feb 2013
    288
    Thank you!
