2007 307 HDi Estate - Whining rear end!
Results 1 to 18 of 18
Like Tree9Likes
  • 1 Post By seasink
  • 1 Post By borosa
  • 1 Post By seasink
  • 1 Post By seasink
  • 1 Post By seasink
  • 1 Post By luthier
  • 1 Post By Stuey
  • 2 Post By pugwash
Thread: 2007 307 HDi Estate - Whining rear end!
    Aug 2012
    Penrith, NSW
    113
    Default 2007 307 HDi Estate - Whining rear end!
    Progressively getting louder on each trip, I know a rear wheel bearing when I hear one!
    Over the course of the weekend I have discovered the following fun facts:
    • Bearings are integrated in the rear wheel hub
    • Bearings are non-replaceable on their own
    • Some models have separate disk rotors and wheel hubs, others are a single assembly.
    • Brake disc calliper reset need to be screwed and pushed rather than just pushed in... Can done manually or with a "special" tool. Definitely femme!
    Mine appears to have the integrated hub and rotor assembly (due to ABS perhaps), so i'll be up for a little more to replace them, but I have seen them come in pairs for around $220, or $280 with a set of pads, which I consider reasonable. The issue I have is I don't know which part to order. The site I am looking at is as below.
    Please let me know if they are a suitable supplier, and if so, how I can tell which one to order. I'll call them in the morning, but though i'd ask here too.
    https://www.empoweredautoparts.com.a...ugeot+307+rear
    TIA,
    AB.
    Aug 2012
    Penrith, NSW
    113
    FYI - Rear callipers are Lucas branded...
    CitroŽn Tragic UFO's Avatar
    9,633
    Contact either EAI or Dapco and ensure you have your car's VIN available. This tells either dealer the exact build of your car and the required parts.
    You will need Torx bits to do this job, not Allen keys.
    A brake piston compressor kit can be purchased via eBay quite cheaply and will come with a variety of fittings or you could buy one from Supercheap etc for more $$.
    However, before you go down the disc replacement path check the wear on all the tyres - rear and front. It could be worn tyres creating a worn bearing sound.
    8,503
    Bearing and ABS ring are integrated, but it's actually quite a simple job. Other PSA cars like the DS3 are similar. LPR are probably the cheapest brand available locally.
    I agree with UFO's suggestions re local supplier and getting the winding tool. Be careful not to damage the ABS sensor.
    UFO likes this.
    Aug 2012
    Penrith, NSW
    113
    Thanks gents. Noted. Parts can be a bitch. If they don't ask for the VIN, they're not doing it right!
    Happy to have already purchased the Torx bits (includes the #50 bit I need for this job) for an earlier job. I am blessed to live within walking distance to European Autocare in Penrith. Denton knows my car well, but I want to do this one myself...
    UFO likes this.
    9,633
    Should add too, it's important to "peen over" the retaining ring when you tighten it up. This of course means you need to "un peen" the old ring. You do this with a punch and hammer.
    You will also need a large socket and bar to remove and replace the retaining ring - I think it's 36mm - but it's a while since I did this job on our Cit C4 (same specs as the 307)
    8,503
    That's something I forgot - the hub covers supplied by LPR and some other makes are [email protected]#$. Save the old factory ones.
    UFO likes this.
    8,503
    Jul 2013
    Newcastle/ central coast
    1,651
    You can do it with two screwdrivers quite easily
    Garage C5 X7 3008 XTE
    Fix it right the first time
    Aug 2012
    Penrith, NSW
    113
    I saw someone on here posted a video of it being done with a G-clamp and a Stillson wrench. So long as the boot is protected, it should be ok...
    Question - is it safe to be driving it with the rear end whining away? It's seriously getting louder than the radio now!
    8,503
    The G clamp is to push in the front wheel pistons. However the rear pistons wind out as the pad wears to take up slack in the parking brake. They have to be wound back to insert new thick pads. There are two holes in the piston for a grip, and it's a great deal quicker and easier than multiple screwdrivers to use the tool - my experience anyway.
    Sometimes a bit of muscle is needed and the tool provides this. They are available very cheaply on eBay to suit Peugeot - $twentyish. Auto tool shops have them too, but for many more $$.
    Replace discs and pads on both sides, for braking balance.
    borosa likes this.
    Aug 2012
    Penrith, NSW
    113
    Ok, next dumb question - right or left hand thread?
    https://www.ebay.com.au/itm/Right-Ha...oAAOSwORRbehjs
    9,633
    Quote Originally Posted by borosa View Post
    Buy a kit with all the bits in it - they include left and right threaded bits.
    8,503
    Some of the kits on that page have two screws for the tool - one each way. You need them. Make sure the kit has the tool fitting for Peugeot/Citroen pistons; the rest are of no present value, so you don't need a large workshop kit.
    The caliper itself is not swinging at the rear, and has to come right off to change the disc. You may find that the old disc has worn severely lipped, making removal a small challenge. The handbrake cable simply unclips. Do not disconnect the hydraulics, tie the caliper up to prevent hose damage, and be careful with the ABS sensor hidden in there.
    Winding back will raise the fluid level under the bonnet - watch it!
    Edit: tool in use - tool-in-use.jpg
    borosa likes this.
    1000+ Posts luthier's Avatar
    Northern NSW
    1,024
    My 2006 HDI has hub and disc as a unit but the abs ring easily pry's off with tyre levers and the bearings can be driven out and in with a press. I just did the job recently as well as replacing the rear pads. I agree to get the ebay screw in brake caliper tool, should have got one years ago for 505 and 504 brakes.
    I'll be really surprised if the bearings can't be fitted to yours. When in doubt ask Lewin with your vin number. 0424063541 0733534448
    O yeah they scream and I wouldn't drive for long at that point. They are a weird bearing with internal tapered cups and big ball bearings. Looks like a cynical marketing exercise to me.
    borosa likes this.
    6,248
    Isn't it an angular contact bearing? Rather than cynical, it's practical. Holds the hub radially and axially without having to adjust a tapered roller arrangement. I'm not suggesting it's better, but it's for ease of manufacture.
    UFO likes this.
    2003 PEUGEOT 206 GTi
    Aug 2012
    Penrith, NSW
    113
    Thanks all. Got the left side done, which was the noisy side. Needed an extra long breaker bar to undo the hub axle nut... Unfortunately, while doing the right side, I have damaged one of the stupid T50 calliper bolts whilst trying to remove it. Top one came off, but bottom one is now damaged and still tight as f***.
    What are my options now? Can these bolts be sourced, and what can I do to extract it?DSC_09283.jpg
    tweed heads
    1,471
    I have been here myself ,you can buy those bolts off e bay with a hex head ,its a funny thread from memory ,try soaking the bolt in inox ,and if possible ,tap the bracket it holds , rotating it on the bolt , back and forth ,i then managed to grip it enough with vise grips to get it off ,there isnt much room to swing in there ,you could try one of those sockets the tyre places use to remove lock nuts, a taper with revers spiraling teeth ,i had considered grinding a hex on the torks head and jamming a socket on it ,those bolts are a major pain ,the worse part of the job pugs
    borosa and UFO like this.
