405 Rear screen
Results 1 to 3 of 3
Thread: 405 Rear screen
    Hobart
    1,492
    Default 405 Rear screen
    Hello All,
    Are these bonded in like the front screen or a dry seal like on the older cars? I am needing to remove the rear screen from my Mi16 project and am wondering the best way to tackle it, having done plenty of 505's in the past!
    Ben
    1989 Peugeot 405 Mi16
    2000 Peugeot 306 XSI
    1973 Peugeot 504 GL
    1000+ Posts pgti6's Avatar
    May 2001
    1,604
    From memory it's bonded but does have a rubber surround mainly for the metal embellishment strip. If you break the glass I have a spare in Melb you can have.
    You'll need one of these though-
    https://www.supercheapauto.com.au/p/.../SPO84864.html
    Lap times-
    Sandown 1 27.9
    Phillip Island 1 53.8
    Previous Frenchies-
    1988 205Gti
    1998 306 GTi6
    1997 306 N5 sedan
    1996 306 N3 XT hatch
    tweed heads
    1,471
    Have used rusty mig wire with two screw drivers as handles ,watch you dont damage the paint work whatever you use .pugs ,ps make a small hole in the glue ,feed the wire through rap it round a screwdriver handle or dowel .someone inside /someone outside ,start sawing ,pays to wedge a little as you go so it dousnt stick back together ,
