Strange ticking
Thread: Strange ticking
    Apr 2019
    Bruthen
    2
    Default Strange ticking
    Hi all, my 405 is making a funny noise that doesnít seem to be coming from the engine. Itís a rhythmic set of 5 ticks followed by a pause then starts 5 ticks again. Happens 5 times every minute and seems to be coming from the gear stick. Itís auto btw. Otherwise running fine
    Aug 2015
    Nagambie
    1,386
    Quote Originally Posted by Winnie Rout View Post
    Like an old Morris Minor fuel pump perhaps)))
    Sent from my iPad using Tapatalk
    8,529
    Listen closely to the heater/ac unit.
    9,628
    Possibly the flap motor in the dash for the climate control? They regularly try to adjust and click when one of the cogs has shed a tooth. I've not yet needed to buy a replacement cog, but see:
    How to replace plastic gears with brass gears for gear-motor of air-conditioned cars
    and for the installation in an XM, which will be similar:
    Citro√ęn DS/ID and XM Web-Site
    Fellow Frogger! Dijon16's Avatar
    Jan 2005
    357
    I second that, more like 99% chance that it is the heater flap motor, which is what happened to my 405 about 20 years ago.
    I think that the stealer wanted about $800 for a new unit. From memory, there is a logic fault in that the motor, same as a slot car one, does not recognise when it is at full travel, and keeps trying to turn.
    There is a small box with the plastic cogs in it, and one gets stripped. Whilst it was easy enough to identify, again from memory, if you take the gears out to replace, they are timed, or aligned, with small arrows on them. If they are not put back in correctly, the same will happen as they will be out of adjustment.
    Happy to be corrected on this.
    6,248
    Easy job to replace; the little box is removable from down in the footwell on the side of the heater box. I sourced brass gears for mine that were beautifully CNC milled but I'm not sure if they're still available.
    2003 PEUGEOT 206 GTi
