504 Parasitic Leak
Results 1 to 14 of 14
Like Tree7Likes
  • 2 Post By robmac
  • 1 Post By robmac
  • 1 Post By seasink
  • 3 Post By aquinian
Thread: 504 Parasitic Leak
    Fellow Frogger! aquinian's Avatar
    WA
    604
    Default 504 Parasitic Leak
    Hello Froggers,
    Have a 504 which has a nasty habit of draining it's battery overnight.
    Have done a parasitic leak test and have determined that the issue on the horn/interior lights fuse circuit.
    However unfortunately this behaviour is random. It was pulling a good 0.25A when off yesterday but today is pulling nothing.
    There is no stereo plugged in at the moment.
    Any ideas what might be causing this?
    Thanks in advance!
    Kind regards,
    Michael
    Sent from my CPH1851 using Tapatalk
    Current: 406 Coupe, 504 Sedan
    Previous: 306XSi, 205GTi, 206Gti, 505 V6, 505 Wagon, 504 Sedan, 504 Wagon, 306Gti6, 306XT, 205Si, Citroen XM, Citroen Xantia
    18,430
    Boot light ?
    dmccurtayne and driven like this.
    Fellow Frogger! stew's Avatar
    Apr 2011
    brisbane
    492
    Mate get the circuit diagram.
    Apr 2014
    kilsyth (lower montrose) vic,
    176
    Hi Michael, try glove box light,clock,cig lighter,hazard light switch as other constant power possible drains,just a thought or two.....jim
    18,430
    The clue is 250mA current.
    Around 3 watts, typically a filament lamp.
    Last edited by robmac; 5th May 2019 at 08:50 PM. Reason: corrected error in wattage of lamp.
    Doush_504 likes this.
    8,503
    I have a 504 circuit diagram, but nothing will shrink it to 100KB and have it readable. If you can reconstruct them I can post the images resulting from tiling the reduced original.
    8,503
    Here it is-
    Join up and rotate clockwise.
    WA
    604
    Thanks for all the help guys - will have a look at the circuit diagram. Already tried the boot/glovebox lights, clock, and cigarette - no luck.
    The thing that's annoying is that it's intermittent.
    7,414
    Robmac is back? I did miss your views.
    Our most Southern Member (Tas)
    272
    Alternator diode ?
    tweed heads
    1,471
    this is a very distant memory ,years ago i returned from town parked the car ,but when i turned the key off it kept running ,as it was nearly dark i disconnected the battery ,and had a look the next day ,the wireing loom ,had worn through and the wire to the coil had shorted to the permanent active going to the starter ,this was ,down near the starter from memory ,i lived at the end of an 8k dirt road so the car copped a fair bit of vibration ,as your problem is intermittent ,could be worth looking at, pugs
    tweed heads
    1,471
    this is a very distant memory ,years ago i returned from town parked the car ,but when i turned the key off it kept running ,as it was nearly dark i disconnected the battery ,and had a look the next day ,the wireing loom ,had worn through and the wire to the coil had shorted to the permanent active going to the starter ,this was ,down near the starter from memory ,i lived at the end of an 8k dirt road so the car copped a fair bit of vibration ,as your problem is intermittent ,could be worth looking at, pugs 504 wagon
    6,248
    Check the push button door switches are securely screwed in and being pushed enough to disconnect every time and the wires are attached properly to the spade connections at the back. Their contacts need an occasional clean anyway with sandpaper so it's worth pulling them out.
    Does the 504 have a push button for the boot or a mercury switch?
    2003 PEUGEOT 206 GTi
    WA
    604
    Thanks for all your help again guys - it seems like the issue was the boot light switch!
    I think it's aftermarket - have attached picture. At any rate - it was spinning loosely in the middle and thus switching on and off randomly - at about 0.25A....
    Kind regards,
    Michael
    Dano, Tom_95 and Doush_504 like this.
