Gearbox fork that moves the thrust bearing
    Fellow Frogger! Justin B's Avatar
    Aug 2003
    Lugarno, Sydney
    236
    HI all,
    WE broke this component when doing the clutch change over the weekend...
    WE've now got the box back in, and tighten up... however, we noticed AFTER this that the actuator for that moves the thrust bearing was broken.
    Can we Replace this via:
    (A) the gap in the gearbox where the fork goes (i.e don't remove the box)
    (B) unscrew the box and let it hang off the input shaft and get in that way
    (c) R & R the gearbox again..
    THanks
    Justin
    Pugsley The 1987 205 GTi Peugeot
    Fellow Frogger! aquinian's Avatar
    WA
    604
    Justin B:
    THanks
    Justin
    If you can't fit it through the existing gap, you can always cut a hole in the bell housing and either leave it open afterwards or pop-rivet a patch over it. I had a mechanic do this once to replace a fork, and he asked me first and the cost difference made me happy to go with it, even though it is a pretty agricultural solution.
    John Lane.
    Current: 406 Coupe, 504 Sedan
    Previous: 306XSi, 205GTi, 206Gti, 505 V6, 505 Wagon, 504 Sedan, 504 Wagon, 306Gti6, 306XT, 205Si, Citroen XM, Citroen Xantia
    9,223
    What model and what box?
    Some have a very wide fork, you'd have to hack a huge hole!
    Nov 2001
    1,640
    If its any consolation Justin, one of my first major "booboos" when bunging an engine back in a 403 a few decades ago was to completly forget to put the thrust bearing in at all! cry
    I'd be very cautious about letting things rest on the input shaft. These things are not designed to carry heavy side loads. Don't want to have to redo it all again , with a gearbox reconstruction thrown in as well!
    I don't know what the 205 housing looks like. John's suggestion could work, but I'd be inclined to pull it all right out and put it back in again, I'm afraid.
    Rod
    Rod's Home Page
    Rod's car page
