504 Indicator gremlins
Results 1 to 7 of 7
Like Tree2Likes
  • 1 Post By ianrobbo
  • 1 Post By robs
Thread: 504 Indicator gremlins
    Member Pughead2's Avatar
    Jan 2011
    Hepburn Springs,Victoria
    98
    Default 504 Indicator gremlins
    Hi All.
    My hazard lights on my 504 don't work,and haven't for a while...not sure why - fuse is fine.
    Today I hit the hazard switch by mistake,thinking it was the rear window defroster ( it was dark)
    Now lost all indicator function,fuse is good still.
    Questions would be ...?
    Where is the flasher unit located ?...and any Pug crew have any thoughts on this before I go to an auto electrical mob.
    Many thanks.
    Cheers.
    Pughead.
    Avisford NSW
    538
    The flasher can isunder the instrument cluster usually
    Doush_504 likes this.
    Jan 2011
    98
    Thanks for that,will test it asap.
    tweed heads
    1,471
    Operate the hazard warning switch while you have an indicator working ,from memory the circuit to the lights go through that switch ,weather its in operation or not ,could be a loose connection .pugs
    Blue Mountains, NSW
    421
    The hazard switch itself is problematic in 504s and 604s. I had a problem with my 604's indicators a while back and it turned out to be the hazard switch. I drew up a wiring diagram (604 and 504 are very similar) which you can grab from this thread.
    Have fun,
    Rob.
    Jan 2011
    98
    Thanks for that info Pugwash and Robs.Its given me a new place to look re a fix.
    Much appreciated.
    Cheers.
    Pughead
    Jan 2011
    98
    Quote Originally Posted by robs View Post
    Have fun,
    Rob.
    Thanks Rob.
    Cancel my pers message, downloaded the pdf thanks.
