High beams
Results 1 to 8 of 8
Like Tree3Likes
  • 2 Post By GRAHAM WALLIS
  • 1 Post By Bruce Llewellyn
Thread: High beams
    Apr 2019
    Bruthen
    2
    Default High beams
    Good morning! Please excuse my ignorance, but Iíve just picked up a 2nd hand Peugeot 405 and have no idea how to activate the high beam headlights. I can make them flash by pulling the stick towards me but not make them stay on. Iíve tried turning the stick all the way like you do on most other cars to activate the high beams but it doesnít seem to make a difference.The headlights are a little dim and really need the high beams on country roads.
    1000+ Posts Kim Luck's Avatar
    Melbourne, Aus.
    17,683
    6,248
    The lever is meant to click when you pull towards you, alternating at each pull between high and low. Click high. Click low. It may be broken.
    Unfortunately the 405 has poor lights without modifying the wiring to increase current to the lamp unit. I never got round to it on mine and the lights were terrible.
    2003 PEUGEOT 206 GTi
    9,107
    Excellent beam pattern though.
    Roland and Doush_504 like this.
    Fellow Frogger! Doush_504's Avatar
    Cairo, Egypt
    623
    Always noticed that since I was a kid.
    But the light intensity itself is weak unfortunately.
    Chadi
    1982 504 SR white manual sedan with A/C (257 000 Km)
    2012 308 1.6 VTi Vapor Grey manual H/B (35000 Km)
    1994 405 1.6 white manual sedan (208 000 Km)
    1992 605 SV24 (91 000 Km)
    2005 406 2.0L automatic (Replaced with a 2013 C5)
    1983 505 GR white manual sedan with A/C (170000 Km)
    All since new
    Fellow Frogger! Roland's Avatar
    Perth
    726
    Probably those pesky poor earthing points on the side panels near the front of the engine bay.
    Give them a good clean up and see what happens!
    Roland
    Land Rover Discovery 4
    406 Coupe D9 - Manual (2002)
    307 Hdi Estate - Auto - (2007)
    307 Hdi Sedan - Auto - (2007)
    505GR Estate - Personal Import from UK 1971cc Manual (March 1986)
    405 Mi16x4 (all the parts ready to install into the LeMans body)
    6,248
    That's a small part of it, but the main reason is the light gauge wire used in the headlight harness. It requires heavier gauge wire from relays driven by the original harness. (I actually half installed this on my old Mi16, but removed my handywork when I gave the car away because I bought top quality relays I wanted to keep). But tested, it made a big difference.
    Oct 2011
    Toowoomba
    647
    There are two relays - one to flash the other holds in high beam when the lever is pulled with the headlights on.
    Dano likes this.
