The diesel particle filter and it's cleaning
Like Tree3Likes
  • 2 Post By dmccurtayne
  • 1 Post By dmccurtayne
Thread: The diesel particle filter and it's cleaning
    Jan 2016
    Mundaring, W.A. Aust.
    19
    Default The diesel particle filter and it's cleaning
    I have mentioned the ongoing issues of the particle filter and the regeneration process, which it seems is the cause of the idle fluctuations during this process. A suggestion was made that blank off the EGR might stop this process. I didn't, eventually a, cleaned and un-blanked, EGR was fitted and there is on change in the occasional idle fluctuation issue.
    As the car has done 225K, I have come to the conclusion that, probable the particle filter needs to removed, opened, and cleaned out. The process I'm told is to put the filter in a high temp oven and bake it, following this it is cleaned by a high pressure blow out. Apparently, this is a relatively common practice on diesel truck exhaust systems.
    Has anyone gone through this problem and this 'cleaning' process; I find it impossible to imaging that I'm the only diesel owner to be confronted by this issue?
    8,529
    What sort of driving has this car done? Normally an uninterrupted run (such as on a motorway or long country drive) will cause the system to regenerate. Eventually the filter will be blocked beyond regeneration.
    Has the car been given a forced regen? This requires the PSA diagnostic software, and can be spectacular, and not done indoors or near vegetation. (The exhaust is hot indeed)
    Many cars and light commercials eventually need a high pressure filter clean. There are businesses set up for it, not only for heavy lorries.
    Jul 2013
    Newcastle/ central coast
    1,674
    A ds150e can also do a regen along with a lot of other scan tools but why not blank the egr to test even when these were brand new less than 10k we had this problem itís not so much a dirty egr rather than an intolerance to the air flow adaption. The whole reason for these block off plates was to stop this. You need to drill a 8mm hole in the middle of the plate to allow some flow. This was recommended by paa at the time and wonít cause any problems with the engine. At the time we would replace brand new valves and still no fix.
    Garage C5 X7 3008 XTE
    Fix it right the first time
    Roland and pugmachine like this.
    Jul 2013
    1,674
    Roland likes this.
