508 HDi 2012 gremlins
    112
    Default 508 HDi 2012 gremlins
    Son's 508 is causing concern. Go to start car, gauges flicker as normal but nothing happens with regard to actually starting. Dealer says "battery", RACV came to the rescue and said battery is fine. Non starting has happened a few times. Sometimes doors do not lock or door mirror does not fold in.
    What are the Aussiefrogs suggestions please.
    Glenn
    Jul 2013
    Newcastle/ central coast
    1,674
    Battery in the key as dealer has said main battery , does the car start if you put the key in the reader ?
    Ignition switch module?
    Garage C5 X7 3008 XTE
    Fix it right the first time
    112
    Thanks for this. This is the car that you diagnosed a seat blowing fuses a while back. Not sure about car strting when you put key in the reader but this sounds like what RACV guy did. I do not have easy access to the car to check suggestions.
    Glenn
    Jul 2013
    1,674
    How did you go with the seat broken / cut wire ?
    The reader is just to the right of the dash under the pull out. If it starts when in there itís the key battery if not I would be doing the main battery these are critical.
    Is the sat Nav upto date ?
    Nov 2002
    44
    I had the same with my 508 GT - twice. Once, it was the battery in the keyfob; another time the car battery was reaching EOL.
    As the keyfob battery charge got lower, starting the engine became inconsistent.
    I found that sometimes placing the keyfob closer to the start button worked until I replaced the battery.
