Car cover- for outdoor storage
Results 1 to 20 of 20
Like Tree2Likes
  • 1 Post By COL
  • 1 Post By pugwash
Thread: Car cover- for outdoor storage
    Oct 2017
    Coburg
    6
    Default Car cover- for outdoor storage
    Hi all, due to renovations Iím about to lose my garage..... permanently. So my 504 will be open to the elements. Does anyone have any advice/ experience with car covers for storing cars outdoors? Have a relatively clean 504 that I want to keep that way. Does anyone keep their car under an outdoor car cover? Any brands or companies they would recommend? I imagine a good outdoor cover would keep any rust at bay?🤞 Any advice/ feedback appreciated. Thanks.
    1000+ Posts Beano's Avatar
    3,185
    No matter how good the cover, won't condensation still form if it's outside, particularly during Winter ?
    1000+ Posts Peter C's Avatar
    SWOTR
    3,803
    Some possible problems - 1. The cover will eventually leak and need replacing and you also need to buy a very good quality one 2. Ensure all window seals etc do not leak otherwise the car will rust from the inside out, i.e, from inside the cabin out. 3. Depending on the surface the car is parked on, you may well get condensation under the car.
    COL
    COL is online now
    A110 COL's Avatar
    Van Diemen's Land
    4,298
    May be better off giving a it a good clean and wax and just wash it regularly.
    driven likes this.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    8,466
    i had my car under a gazebo type structure for a decade or so and it did a great job of protecting the car from the elements.
    SWOTR
    3,803
    I reckon a gazebo carport thingo would be great. One problem I had with car covers is that they stop air circulation and any trapped moisture wont evaporate.
    Fellow Frogger! Dijon16's Avatar
    Jan 2005
    393
    Some of them are vented, with flaps over the vents. Will not circulate freely, but better than nothing.
    Get one that is 2 layers, with a solid outside and a fine fabric inside. Some have tabs to secure to the wheels.
    Oct 2017
    hawthorn melbourne
    114
    Your location in Coburg is not a place with high humidity or salty air so a car parked in the street shouldn't rust .If you do get a cover get one that is 2 layers and remove it on fine days so its not on for too long.
    Fellow Frogger! neural revolt's Avatar
    Frenchs Forest/Sydney/Australia
    327
    Be careful if the car is parked in a windy area. Wind can blow dust and grit into areas between the cover and the paintwork. This, combined with any movement or flapping of the car cover can damage the car's paint work over time.
    I 've used Col's suggestion; a good clean, wax and regular washing.
    Past Frogs:
    Alpine White 1967 R10 (round eye)
    Alpine White 1972 R16TS
    Blue 1978 Virage Wagon
    Current:
    Red 2009 Clio RS 200 CUP
    16,716
    As soon as I can afford it, I'm going to use something like this.
    https://www.ebay.com.au/itm/SHEDS-18...EAAOSwa0VaA7F2
    Oct 2002
    Melbourne Victoria
    12,527
    Default Car port covering - durable
    I was watching a cable TV program a few days back and the mission was to build a hothouse in snow country and they used a simple hoop design for the uprights and then put a clear cellular material over top as a roofing material not sure how durable their material was as it looked almost like clear Corflute style material (Plastic cardboard) and that was locked down on the hoops with screw fasteners, quick and easy construction and said to withstand heavy winter snow cover.
    Thought at the time this would make a nice easy carport cover to drive in under and easily removable and relocatable as a two man job.
    Had a look at materials (didn't look for corflute as that is probably not up to the durability test) but there is this stuff, probably expensive. just an idea as from what we have seen on other threads like this every car cover has problems ranging from trapped condensation (rusting) or abrasion.
    Polycarbonate Honeycomb Plastic Sheet , Greenhouse Clear Roof Panels For Pergola
    Ken
    1000+ Posts driven's Avatar
    Apr 2005
    1,549
    Any car cover touching the paintwork will wrecking the paint job....Guaranteed
    Best bet go to a retirement village and find a vacant spot to store your car
    SWOTR
    3,803
    What about one of those things that look like a plastic walled nissen hut?
    Mar 2013
    olinda victoria australia
    755
    I used good covers for some time and they help a bit but don't keep the car truly dry, especially if parked over grass or dirt - any greenery pumps out water and oxygen ( photosynthesis ) and damp in the ground evaporates up.
    Cars rust from the inside out
    There are pod type devices which also have a floor
    At the very least I would have it on black plastic or suchlike and would try to ensure that any cover allowed good circulation and did not touch the paintwork. This gets you into the upper league of car covers
    Try to use the car as much as possible
    Andrew
    4,424
    Quote Originally Posted by Peter Chisholm View Post
    Carcoon?
    KB
    tweed heads
    1,526
    Whatever you use make sure you arnt making a nice cozy place for rodents to camp for the winter ,i recently sold an old vw van i have owned for 8 years, on inspection the prospective buyer found the left hand low beam and indicator not working ,after replanting globes with no result ,i followed the wiring loom under the van to find a section eaten out by bush rats ,4 wires with about 3cm missing all together ,i had to solder ,new bits in ,all my cars now have wax block baits installed ,which are continually being chomped on ,and they particularly like leather ,i had a customer that had there recaro seats totally ruined by rats ,they found there way in by chewing through the gear shift boot ,im on a rural block ,pugs
    Kenfuego likes this.
    SWOTR
    3,803
    This is turning into a useful thread on the pitfalls and problems of storing cars outside. Good info. Seems like there's nothing quite like a good shed.
    COL
    COL is online now
    A110 COL's Avatar
    Van Diemen's Land
    4,298
    That should also be rodent proof if you live on a rural block, otherwise you will have the same rodent problem.
    Regards Col
    1973 Alpine A110
    Oct 2017
    Coburg
    6
    Thanks all, I think Iíll try some of my neighbours who may have a spare garage. Sounds like long term, a car cover wonít be a great option.
    Apr 2013
    Essendon
    699
    Car covers are not a substitute for a "gsrage" and never were.
    They were made to provide protection solely from sun, bird droppings and tree sap.
    And I'm pretty sure that instructions that come with it tells you to take it off often.
    John
