Pug 205 GTI Fuel Problems
Results 1 to 8 of 8
Like Tree2Likes
  • 1 Post By BIGRR
  • 1 Post By schlitzaugen
Thread: Pug 205 GTI Fuel Problems
    Apr 2017
    Gold Coast
    19
    Default Pug 205 GTI Fuel Problems
    First off, I'm no mechanic!
    Alright lads, so, had another mechanic come have a look at Pugsley today and try and sort out this fuel issue I've been having. After a few hours of tinkering, she still doesn't want to start.
    Managed to get it started up briefly on easy today, so it wants to start. Mechanic no.1 reckoned the pump shit itself, so we replaced it. It was just getting fuel up to the rail and even whilst cranking the manual relay it still didn't want to start. Now after today and mechanic no.3, says the same thing, has spark, fuel is the problem, he says it wasn't getting past the filter now, he now recons there could be a blockage in the lines causing poor flow or possibly the pump again, although he did say the pump was trying it's hardest, he did take the line off etc to the pump and manage to get some fuel out, it was pretty yellow and stank, so I guess the next step is to clean the tank out.
    This is the 3rd, yes the 3rd mechanic to look at it and walk away with no definitive answer as to why it won't start, all they say is it's defo a fuel problem 🤦*♂️ they all look completely puzzled 😂
    Anybody on or near the Gold Coast know of a decent mechanic that knows these cars??
    Jul 2013
    Newcastle/ central coast
    1,674
    Has anyone put a noid light the injectors itís pretty simple to check fuel pressure at the rail how old is the fuel
    Garage C5 X7 3008 XTE
    Fix it right the first time
    Apr 2017
    Gold Coast
    19
    Mechanic had a noid light in them today, they were fine and pulsing apparently. The fuel, well I tried to empty as much as I could out of the tank about 6 month ago before putting about another 10ltr of fresh in, but what the mechanic took out today was a little yellow.
    1000+ Posts BIGRR's Avatar
    Feb 2006
    North Rocks, Sydney
    2,385
    I had the rubber fuel delivery line between the filter and the steel pipe at the fire wall collapse internally on my 205.
    dmccurtayne likes this.
    Present fleet:-
    Peugeot 93' 205 Gti 16v
    Peugeot 73' 504 Ti from new
    Previous fleet:-
    Peugeot 95' 605 Sv
    Peugeot 92' 205 Gti
    Renault 72' 16TS from new
    Renault 69' 10
    Renault 71' 10s
    Renault 68' 10 from new
    "Be reasonable do it my way!"
    Feb 2013
    Sandringham/Victoria
    464
    Maybe get them to put a fuel pressure gauge on the fuel rail if possible.
    Quote Originally Posted by greggwynne View Post
    Apr 2017
    Gold Coast
    19
    Took the fuel filter off today and there was no fuel in it, dry. Blew down the line and could heat it bubbling in the tank, so surely it can't be a block. I've ordered another fuel pump
    8,775
    Air bubbling in the tank doesn't mean the hose is not blocked. Think of how a one way valve works. That's what's happening with your fuel supply line to the filter. There may be some gunk that can move a couple of mm up and down and gets wedged when pushed from the tank by petrol. Air also flows differently to fluid.
    You are trying to blunder your way through this problem instead of being methodical. I reckon this way you're going to go through a lot of mechanics. Cut it short and find one with a fuel pressure gauge next. Better still, go buy one and check for yourself. I reckon by now you could have paid for one with the mechanics' fees. The gauge is going to tell you if any fuel makes it through to the engine. If not, well, at least you know what to look for. If you changed the pump with a new one, you shouldn't have any problems there but I would still uncouple the banjo, put it in a bucket and crank the engine see what happens.
    Now that you want to replace the pump a second time, before you throw it out, why not try it on a battery directly? Just for a few seconds to make sure it spins, buzzes, does something, whatever (or not)? Was this replacement pump new or s/h?
    Anyhoo. Starts to sound like the re-run of a bad movie.
    ACHTUNG ALLES LOOKENPEEPERS
    1,645
    Correct, blowing shows its open but air is different to petrol in many ways so bubbles do not show the fuel line is out of the picture. Test fuel pump externally as recommended to show its either ok or not
    307 HDi wagon
    407 HDi wagon
