2009 308 battery light
Results 1 to 3 of 3
    esj
    esj is offline
    Mar 2018
    6
    Default 2009 308 battery light
    Any advice on this matter please: Had a flat battery and went to Kmart Auto. They changed the battery but afterwards the battery light was on along with a warning sign "battery or electrical supply fault". the mechanics there tried with over an hour to reset the system etc but no joy. According to them it is charging correctly but they do not have the software to reset the warning light. Anyone else encountered this issue before, and how did you resolve it?
    Jakes
    Jul 2013
    Newcastle/ central coast
    2,222
    What motor is it if itís a turbo 1.6 petrol check all the 10 amp fuses in the engine bay if one is blown the turbo water pump is probably gone disconnect the plug from the pump and replace the fuse you should then be able to clear the faults from the bsi and engine ecu get the water pump replaced and stay well clear of Kmart
    Garage C5 X7 3008 XTE
    Fix it right the first time
    Garage C5 X7 4008
    Fellow Frogger! Doush_504's Avatar
    Cairo, Egypt
    640
    You don't need any reset after battery replacement.
    Maybe re-initialising auto window switches and that's about it.
    You should check the alternator and the accessory belt.
    Chadi
    1982 504 SR white manual sedan with A/C (266 000 Km)
    2012 308 1.6 VTi Vapor Grey manual H/B (52000 Km)
    1994 405 1.6 white manual sedan (236 000 Km)
    1992 605 SV24 (91 000 Km)
    2005 406 2.0L automatic (Replaced with a 2013 C5)
    1983 505 GR white manual sedan with A/C (170000 Km)
    All since new
