406Hdi not charging
    Fellow Frogger! Ren25's Avatar
    Dec 2002
    Perth
    299
    Default 406Hdi not charging
    Hi all,
    Having a problem with my D9 406 Hdi. Not charging. Battery light on and "Charging Fault" on display. I have removed the alternator and tested it according to Youtube with test light, multimeter and electric drill and it tests OK. Replaced the "engine running signal relay", still no go.
    Any ideas?
    Armageddon was yesterday
    Today we have a problem
    2000 406 Hdi X 3
    2003 307 Hdi
    Jul 2013
    Newcastle/ central coast
    2,222
    When you hold the inside of the alternator does the clutch lock one way and not the other when loaded they can slip but will spin normally.
    There also is an earth at the front of the motor on the bell housing that is notorious for coming loose while the multi meter is out do a voltage drop test from positive battery to positive alternator and negative battery and engine and body earth should have almost zero (with the engine running )
    Garage C5 X7 3008 XTE
    Fix it right the first time
    Garage C5 X7 4008
    Dec 2002
    Perth
    299
    Quote Originally Posted by dmccurtayne View Post
    Thanks DMC. I checked the clutch, its all good. Will check the rest in the morning.
    2000 406 Hdi X 3
    2003 307 Hdi
    Dec 2002
    Perth
    299
    Done all those checks, all OK.
    However there is no voltage to the small terminal on the alternator with the ignition on.
    Beginning to think it's the BSI.
    2000 406 Hdi X 3
    2003 307 Hdi
