[BRIS] 206 Gti 180 | Oil Leak | Engine Rear Main Seal
Results 1 to 11 of 11
Like Tree6Likes
  • 1 Post By 1pugnut
  • 1 Post By Stuey
  • 1 Post By pugwash
  • 1 Post By Stuey
  • 1 Post By pugwash
  • 1 Post By SLC206
Thread: [BRIS] 206 Gti 180 | Oil Leak | Engine Rear Main Seal
    Member FUN206's Avatar
    Sep 2018
    48
    Icon5 [BRIS] 206 Gti 180 | Oil Leak | Engine Rear Main Seal
    Hey everyone,
    I have an oil leak from Engine Main Seal. Probably means a gear box out job. Any recommendations for a good mechanic in Brisbane to do this work. From what I understand, it's a gearbox out job, and loosening the engine mounts enough to get to the seal..? Also, a good time to do fresh engine mounts?
    Any other tips?
    Cheers all,
    _________________
    Garage:
    2005 Peugeot 206 GTi 180 [103,000km]
    Fellow Frogger! 1pugnut's Avatar
    wollongong
    444
    I would inspect the engine mounts and only change them if they need to be changed they are easy enough to change at any time,
    but I would change the clutch and clutch fork and the gearbox input shaft seal and seal housing while the box is out.
    Or at very least the gearbox input shaft seal and the seal housing clutch fork and thrust bearing.
    Regards Jamie
    FUN206 likes this.
    series 2 405 mi16
    205 si
    series 1 205 gti
    series 3 205 with a gti6 motor project
    1970 404 ute 504 ti motor project
    parts cars 2 205 si's 306 sedan
    2004 206 gti180
    6,648
    And replace the driveshaft seals on the box.
    FUN206 likes this.
    2003 PEUGEOT 206 GTi
    Sep 2018
    48
    Awesome advice!! Thanks Guys!!
    _________________
    Garage:
    tweed heads
    1,509
    Check the crankcase breather isnt blocked ,pugs
    FUN206 likes this.
    Sep 2018
    48
    Quote Originally Posted by pugwash View Post
    You reckon it could be that?? So definitely do this before dropping the gearbox out?
    _________________
    Garage:
    6,648
    How many kays has it done? The original rear main seal lasts quite a while usually.
    FUN206 likes this.
    tweed heads
    1,509
    Could be that excessive crankcase pressure has worn the seal prematurely ,my son had an old volvo that had blown the rear seal out of the block completely ,through a blocked breather ,pugs i agree with stuey ,rear seal seems to be an issue we would relate to a much older car .
    FUN206 likes this.
    Sep 2003
    North Parramatta
    4,002
    There's also a chance it's another plug on the block, like this one:
    Oil plug
    FUN206 likes this.
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
    Sep 2018
    48
    Got all the info guys - thanks so much everyone!! I've learnt heaps here .
    _________________
    Garage:
    Sep 2018
    48
    102,500 kms... That's what I would have thought too...
    _________________
    Garage:
