Minor water leak solution?
  • 1 Post By Stuey
Thread: Minor water leak solution?
    Fellow Frogger! dhaw's Avatar
    Feb 2005
    SYDNEY
    538
    Default Minor water leak solution?
    Coolant low and noticed water dripping from bottom of car. Took to mech and he said the water pump had been leaking but wasn't now. $600 to replace so drive it and see. Every three days I have to add about 200ml to the system. What do we think of BARS LEAKS RADIATOR STOP LEAK? Does it harm the car or the radiator to add this to try and seal the leak? ( Pug 2008 )
    Previously 404 1969, 505, 504 1977, 405 MI16 1991, 205SI ,306GTI6 1997
    Currently 306GTI6 1999 and 2008 Active 2013
    6,645
    I believe there are more modern stop leak products now that may have fewer negatives, but for the life of me I can't remember where I saw them discussed!
    The potential trouble with Bars Leaks is that it works reasonably well on static leaks but (only using logic, not experience) it may not on pump seals because of movement. It relies on the solids in the solution entering the leak gap and solidifying with exposure to air, I understand. Hopefully someone can pipe up that's tried it (I have for my 405's heater and it worked).
    dhaw likes this.
    2003 PEUGEOT 206 GTi
    Jul 2013
    Newcastle/ central coast
    2,222
    Some 2008s have extensions on warranty on the water pump check with the dealer donít put that stuff in a ep6
    Garage C5 X7 3008 XTE
    Fix it right the first time
    Garage C5 X7 4008
    1000+ Posts driven's Avatar
    Apr 2005
    1,519
    Bars leaks won't work on Water Pump.
    Bush Mechanic Raw Egg works just as well as Bars Leaks
    Small leak will turn into a gusher and will cook the engine from loss of coolant
    As they say
    6,645
    I should have added, I wouldn't use Bars or similar products on a car I cared about normally but when I did, there was no chance of me doing a heater matrix job on the 405 for personal reasons. I answered on that basis - that there's a good reason (such as lack of cash!). But anyway, I think the concensus is no.
