2004 Peugeot 307 AL4 Automatic Gearbox Issue
Results 1 to 17 of 17
Like Tree2Likes
  • 1 Post By dmccurtayne
  • 1 Post By dukbilt1
Thread: 2004 Peugeot 307 AL4 Automatic Gearbox Issue
    Jul 2013
    Maitland NSW
    76
    Default 2004 Peugeot 307 AL4 Automatic Gearbox Issue
    Hello everyone,
    I went to search the forum for the tricks to resolving AL4 woes - but the posts have gone! What happened?
    So, I have recently had a couple of issues where the gearbox has shifted out of 4th (twice in exactly the same spot in exactly the same journey, followed by another event today on a completely different route).
    Each time I have simply turned the car off and then on again, then continued on my way with no further issue, but there is an issue I wish to resolve. I gather the first thing to do would be to top up the oil - what's the slippery stuff of choice?
    Is it worth changing filters at the same time?
    Is it worthwhile attempting to replace solenoids as well?
    Thanks,
    Ewan
    Jul 2013
    Newcastle/ central coast
    2,222
    Have you had it scanned do you have p06 line pressure fault
    Garage C5 X7 3008 XTE
    Fix it right the first time
    Garage C5 X7 4008
    Jul 2013
    Maitland NSW
    76
    No - I'm about to do that later this evening. I will post the information when I get it.
    Jul 2013
    2,222
    Iím down in Newcastle if you need help
    Garage C5 X7 4008
    Jul 2013
    Maitland NSW
    76
    PM sent.
    9,356
    I've got a good AL4 from a 2 litre Xsara available, not expensive but in Melbourne.
    Jul 2013
    Maitland NSW
    76
    It looks like it has the P06 failure, as well as P26 (Injection Throttle Potentiometer?):
    Permanent fault. Fault in pressure regulation (Variation / recommendation) .
    fault code : 06
    fault appearance counter : 2
    engine speed : 2048 rpm
    turbine speed : 2048 rpm
    AUTOMATIC GEARBOX OUTPUT : 2272 rpm
    oil pressure : 3.65 bar(s)
    guide pressure : 3.6 bar(s)
    gear engaged : 4 locked up
    Position of the gear lever : D
    converter : de-bypassed
    output EVM : activated
    OIL TEMPERATURE : 45 deg. C
    accelerator position : 14 %
    engine torque theoretical CAN : 86 Nm
    control unit supply voltage : 13.9 Volt(s)
    Remote permanent fault. Injection throttle potentiometer (CAN). No signal.
    fault code : 26
    Jul 2013
    2,222
    That second fault is pretty standard after a p06 valves and oil needed
    Garage C5 X7 4008
    Jul 2013
    Maitland NSW
    76
    A couple of questions:
    1. Is it possible/recommended to remove the AL4 gearbox cover without removing the radiator when replacing solenoids?
    2. Is it possible/recommended to use the old gearbox seal when refitting the AL4 gearbox cover?
    Thanks,
    Ewan
    Jul 2013
    2,222
    Yes and yes
    Garage C5 X7 4008
    Aug 2016
    Sunshine Coast, QLD
    933
    The other thing 2 check as my wife's C5 with AL4 is to check the neutral position switch on top to the gearbox is set correctly by measuring 0 ohms across the 2 terminals. My wifes doesn't and no adjustment fixes the issue but I have a spare switch to install when I get around to it. We just live with this issue after rebuilding the AL4.
    9,356
    I have a perfectly good AL4 available if anyone needs one. Out of a 2003 XSara 2 litre which was rear ended.
    Jul 2013
    Maitland NSW
    76
    Graham,
    where are you, and how much do you want for it?
    Jul 2013
    2,222
    Diff ratios and emission references need to be confirmed before you buy a second hand box they are all different
    David S likes this.
    Garage C5 X7 4008
    Aug 2016
    Sunshine Coast, QLD
    933
    You will need to confirm auto box number stamped to the outer case, wheel cover removed and case cleaned off to read it.
    Usually 6 alpha- numerical characters.
    9,356
    Quote Originally Posted by dukbilt1 View Post
    Graham,
    Dandenong, Melbourne. Won't want a lot, it is of no use to me.
    Jul 2013
    Maitland NSW
    76
    So - over the last month or so, I have:
    1. Performed part fluid changes. Penrite ATF was on special! No great change. Original fluid was a morbid grey colour.
    2. Changed the valves - thanks to advice from this forum, and dmccurtayne for his insight and the valves themselves. It took about 4 hours in my garage but the job wasn't particularly difficult.
    The car runs like a dream now - thank you everyone!
    dimistyle likes this.
