(N00b) Rear Brake pads for Peugeot 308
Results 1 to 7 of 7
Like Tree3Likes
  • 1 Post By dmccurtayne
  • 1 Post By Roland
  • 1 Post By seasink
Thread: (N00b) Rear Brake pads for Peugeot 308
    Feb 2016
    QLD
    8
    Icon5 (N00b) Rear Brake pads for Peugeot 308
    Hey guys,
    How is it going?
    I have a Peugeot 308, 2010 Diesel Hatchback model. The rear brake pads needs replacing and the local mechanic only has bendix pads which I don't like. If I wanted a QFM, TRW or Brembo pad, how can I find the right part number? is there a way to get it from the VIN number? Reason being different sites give different parts for same rego number. I am also not sure if it's an XS HDi or XSE Hdi. May be the rego details are wrong. Had a close call not too long ago, and hence need a good brake pad which can stop fast.
    From what I could find this would fit but I don't know whats a (4E_, 4H_): https://www.bremboparts.com/asiapaci...oducttypes=Pad
    But the list has two different diameters and thickness! Are front and back same?
    EDIT: VIN VF34C9HR8AS168341
    Jul 2013
    Newcastle/ central coast
    2,222
    What’s the vin
    Garage C5 X7 3008 XTE
    Fix it right the first time
    mefrog likes this.
    Garage C5 X7 4008
    Feb 2016
    QLD
    8
    Hi dmccurtayne
    It's VF34C9HR8AS168341
    Quote Originally Posted by dmccurtayne View Post
    What’s the vin
    Jul 2013
    2,222
    You have the TRW pads with 249 mm rotors this is all you need for aftermarket
    Garage C5 X7 4008
    Feb 2016
    QLD
    8
    Is there a way to find which are the matching part numbers?
    I presume this will work then https://www.repco.com.au/en/parts-se...330/p/A9513205?
    Fellow Frogger! Roland's Avatar
    Perth
    727
    Hi Mefrog,
    If you are after significantly better braking performance then just putting a softer pad on the rear won't have much effect.
    The rear brakes are only responsible for about 10-20% of the braking.
    Also you will have different specification pads front and rear.
    You are better off changing front and rear to the same specification and same brand.
    Softer pads will give you better performance but obviously will wear more quickly.
    As dmccurtayne has indicated - go to your brake supplier and quote what is fitted already (TRW).
    A performance shop may be your best bet for a significantly better performing set of pads.
    Roland
    mefrog likes this.
    Land Rover Discovery 4
    406 Coupe D9 - Manual (2002)
    307 Hdi Estate - Auto - (2007)
    307 Hdi Sedan - Auto - (2007)
    505GR Estate - Personal Import from UK 1971cc Manual (March 1986)
    405 Mi16x4 (all the parts ready to install into the LeMans body)
    9,239
    There are so many variants in PSA cars always search for parts by VIN. The Repco site search by registration number is almost comical.
    Repco may be able to check by VIN that if asked, otherwise talk to one of the usual French parts suppliers like EAI or Parts of France. They may be interstate, but a courier will have them there in a day.
    mefrog likes this.
