504 Door Card Retrimming?
Results 1 to 7 of 7
  • 1 Post By Andrew Watkins
Thread: 504 Door Card Retrimming?
    Fellow Frogger! Tom_95's Avatar
    Jul 2011
    Sunshine Coast, Queensland
    205
    Default 504 Door Card Retrimming?
    Hi all,
    Like the vast majority of 504s out there, the door cards/skins have developed a few cracks in the upper black vinyl section near the window sill. Since replacements for these are seemingly unobtainium, I'm wondering if anyone has had much luck getting theirs re-trimmed?
    Looking at the back of the door cards, it looks like the black piece may be able to be removed by a competent auto trimmer... However I'm assuming that sourcing vinyl in the correct 'grain' will be nigh impossible.
    Alternatively, if anyone here has a set of front door cards, with the early-style tan inserts (horizontal line pattern) in good condition that they're looking to part with, I'd love to hear from you.
    1975 Peugeot 504 GL | 2018 Suzuki Swift GLX Turbo
    Fellow Frogger! Pug72's Avatar
    Feb 2013
    319
    Hi Tom
    This is something that I am interested in as well. My 72 is starting to develop a few cracks in the black vinyl and it feels very dry and brittle no matter how much armourall I put on it. Finding a good auto upholsterer is not easy. Maybe Dan who is restoring the 404 might have an idea here.
    Andrew
    Mar 2013
    olinda victoria australia
    755
    Hi
    I got my 404 door trims done by a crowd in Sydney - Prostitch
    Classic British & German Automotive Restoration Textiles
    Their website is " Classic British and German "
    I had the dead bodies, which I sent up with a sample of the vinyl with which I wanted them done.
    They did a good job , reproducing them pretty much exactly
    They back them on to MDF. It would be wise to ask for the MDF to be coated with marine grade epoxy before the vinyl is put on as, at least on the 404, the doors suck in moisture from the bottom ( not just from the top down the windows ) and the MDF expands and warps. Not sure whether this is an issue with the 504
    I found them willing to do "one off" jobs and to apply thought to them. They were not especially cheap ( ~700.00 the set 5 years ago ) , but one can't get good work done for nowt, so shouldn't complain.
    Am happy to recommend them - reliable, honest and good quality
    Good luck
    Andrew
    Dano likes this.
    1000+ Posts Dano's Avatar
    Apr 2012
    1,397
    Hi Tom and Andrew,
    As an interim measure and depending on how badly the top black pads are cracked or starting to become brittle, try applying genuine lanolin oil into the plastic. Via a clean soft cloth (old terry towelling nappies are perfect) apply a liberal coating and allow it to soak in, overnight if possible. With another clean cloth, gently rub the residue in/off. Thanks to Bruce Llewellyn, who suggested this method to me, when looking for a way to soften up a hardening and creaking (when pressed) 404 dash pad. The transition was amazing. Naturally, results will depend on the starting condition of your pads.
    As for the door cards, are the linings vinyl or fabric? If vinyl and you want to keep the original look, they can be revived professionally.
    My 404 vinyl linings were refurbished by Lee Brothers Trimmers, situated at Albion, Brisbane.
    https://www.leebrotherstrimmers.com.au/
    I dealt with Warren Lee, one of the brothers. From experience, a personal visit is better than a phone call.
    Within post numbers 124 & 132, on pages 5 & 6 of my 69 404 restoration thread, there is information on how the cards were refurbished and advice given by Lee Brothers. There is also some before and after picks of the results.
    Hope this helps.
    Dan
    Feb 2013
    319
    Thanks Andrew and Dan
    I'll give Lee Brothers a visit as they are close to home. It's only my front door cards that needs some work. The material is all vinyl with the backing made from masonite I believe.
    Moisture isn't too much of a problem as I only recently replaced the window scraper seal.
    Jul 2011
    205
    Hi all, thanks for the input. I agree with Pug72 in that Lee Bros. sound like the best bet.
    Dec 2010
    Mangonui NZ
    83
    Use treated 2mm ply. Stronger & more plyable
