406 temp sensor
Thread: 406 temp sensor
    Armidale
    2,550
    Default 406 temp sensor
    Does anyone know the secret to dismantling the near side external rear vision mirror from a D9 406?
    My external temperature sensor is giving ridiculous readings - currently shows 45C, when it's 13C outside. No it's not in Fahrenheit - I tried switching the setting, and it now shows 111F!! I am assuming there's no re-calibration possible via PP2000 (and anyway, it's not consistent in it's error).
    I got the mirror off without any problems, but whereas it's easy to access the temp sensor in a 605 or Xantia, there is no separate panel giving easy access to it on the 406. My attempts to split the casing have only resulted in breaking tabs off the painted cover so far !
    Alternatively I suppose I could just buy a 2nd hand mirror with working temp sensor.
    Alec
    1000+ Posts cav91's Avatar
    Romsey, VIC
    2,342
    You'll need to pop the glass off first. Actually really easy once you find the clips. I've replaced that sensor on my d8 twice!
    Sent from my SM-G930F using aussiefrogs mobile app
    2017 Renault Koleos auto
    Fellow Frogger! sfrawley's Avatar
    Feb 2001
    Goolwa SA
    341
    It could be just the plug that connects the temp sensor to the car. From memory I removed the triangular panel on the inside of the door that allows access to the mirror mount.
    Stephen
    '03 P406 HDI
    '16 Renault Master
    Armidale
    2,550
    Quote Originally Posted by cav91 View Post
    Thanks cav - great to know that someone else maintains their 406! Sounds like I'd better do it over grass, as I'm sure to lose my grip on that glass when it pops free! Can you give me a clue as to what tool to use etc.? Do you push a screwdriver into the gap between glass and plastic housing?
    Quote Originally Posted by sfrawley View Post
    Thanks - I had to get the triangular panel off and disconnect the single (quite large) electric plug to remove the mirror from the car (assuming that would help me get to the temp sensor ). Replacing it has not made any difference, and I was careful to ensure that the electrical plug was pushed home fully.
    Alec
    Romsey, VIC
    2,342
    [QUOTE=Armidillo;1606317]Thanks cav - great to know that someone else maintains their 406! Sounds like I'd better do it over grass, as I'm sure to lose my grip on that glass when it pops free! Can you give me a clue as to what tool to use etc.? Do you push a screwdriver into the gap between glass and plastic housing?]
    Usually just gently prying the glass away. But very carefully. You can also see the clip if you pry it away enough. I just unhook any part of the clip and the glass comes off.
