Air in the fuel line - 307 2.0HDi
Results 1 to 21 of 21
Like Tree3Likes
  • 1 Post By dmccurtayne
  • 1 Post By Armidillo
  • 1 Post By sgt_doofey
Thread: Air in the fuel line - 307 2.0HDi
    111
    Default Air in the fuel line - 307 2.0HDi
    Hi all,
    Thought I'd ask on here before I take a look at the car tomorrow. The last couple of mornings and this evening, I've had the car start on me perfectly fine, run for about 10 seconds and the die. I can only then start it again by turning it over and pumping the primer bulb by the fuel filter. Once it catches, it then runs and drives fine.
    Now, this must be air getting in to the line somewhere. It takes a while for it to build up. I.e. car sitting all day or all night. If it sits for a few hours, it still starts and runs OK.
    Any idea where I should look tomorrow for where the air might be getting in to the line?
    Jul 2013
    Newcastle/ central coast
    1,762
    On the fuel filter housing input you will find a little fitting between the line and the filter they suck / bleed air from there you can also check the orings where the pipes attach.
    Stop bothering me when Iím vacuuming my room
    Garage C5 X7 3008 XTE
    Fix it right the first time
    sgt_doofey likes this.
    Armidale
    2,286
    Quote Originally Posted by dmccurtayne View Post
    Stop bothering me when I’m vacuuming my room
    Stop looking at your computer/phone while you are supposed to be vacuuming!
    dimistyle likes this.
    Jul 2013
    1,762
    Thatís in reply to Sargent doofey scary movie fame.
    Jul 2013
    1,762
    1000+ Posts FIVEDOOR's Avatar
    Jun 2011
    Brisbane Qld
    20,002
    Dont look, you dont want the imprint of that image
    Every day is a good day
    111
    All these years I've been on forums and no one has gotten that reference! Well done sir! Well done!
    Thanks also for the info. I'll go and check them out.
    Jul 2013
    1,762
    I aim to please
    111
    Well, I think I've found the problem...
    Now the question is, what's causing it?
    Car will be laid up until Monday now as we're travelling from Adelaide to Melbourne tomorrow so won't get a chance to look at it until we get back.
    Is that just simply an o-ring on this type of filter or is it a complete failure and requires a whole new assembly?
    In other good news, it's easy to bypass the fuel filter. The input line clicks in nicely to the output!
    Jul 2013
    1,762
    Thatís the fitting I was talking about
    111
    If you look at the second photo, I joined the two together to bypass the filter. So the o-ring on them were fine. It's the actual filter where it's leaking.
    Jul 2013
    1,762
    Thatís a fitting and is removable
    111
    Ahhh, gotcha!
    It's not leaking from there though
    Jul 2013
    1,762
    Is it the main filter oring not really common if changed
    Nov 2013
    springwood
    7
    Hi. My wife has a 2006 307 2.0ĺ hdi. I found the fuel filter gets blocked and let's air in. Changing filter fixed my air fault...
    Andrew
    Sent from my SONY XPERIA using Tapatalk
    111
    Nothing like a trip to Melbourne and then a bout of gastro to delay the inevitable!
    Finally looking at this and have removed the filter from the car. Next question is how do you open this up? Judging by the looks of it, it screws off at the top.
    If that's the case, then that's where the leak is and I might only be up for a new filter an o-ring!
    111
    It screws off! A bit more muscle was required.
    Found the problem...
    diode1111 likes this.
    Nov 2013
    springwood
    7
    Thought as much! Owing comes with filter. Should be changed at same time as filter
    Nov 2013
    springwood
    7
    ...o ring
    111
    $60. Just got to wait for it to turn up from Peugeot now!
    111
    All fixed now! Thanks all for your help and advice.
    Next question, how do you get rid of the smell of diesel off of your hands?
