Cage nuts for tow bar fitting 406 sedan, D9
  • 1 Post By garryw
Thread: Cage nuts for tow bar fitting 406 sedan, D9
    Mar 2011
    Lake Macquarie
    47
    Default Cage nuts for tow bar fitting 406 sedan, D9
    I have managed to find a tow bar at a wreckers. I have a 2003, 406 hdi sedan. Will need the cage nuts x 6 that slide into the sub-frame. Anyone have any thoughts about where to source them in NSW? Aust? Found a website in the UK but not cheap and may take a while.
    1000+ Posts Peter C's Avatar
    SWOTR
    3,762
    I removed a tow bar from a D9 406 a while. The "cage nuts" in the sub frames were merely nuts (don't know what grade) with long bits of stiff (fencing?) wire welded onto them.
    It appears that the nuts are inserted through the sub frame hole towards the front of the car using the wire to located the nut till it's bolted. After installation they seem to have been snipped off through the hole in the sub frame forward of the attachment bolt.
    Jul 2013
    Newcastle/ central coast
    2,222
    They have nuts on wires if you really want original contact best bars in nz the will have some
    Garage C5 X7 3008 XTE
    Fix it right the first time
    Garage C5 X7 4008
    Nov 2003
    51
    I've just had to pull the tow bar off a 406, and now need to put it back on. I also need the cage nuts. I'm making mine. I could make you a set. No charge.
    Garry
    hypermiler likes this.
