504 noisey waterpump
Results 1 to 13 of 13
Like Tree3Likes
  • 1 Post By pugwash
  • 2 Post By COL
Thread: 504 noisey waterpump
    Member Pughead2's Avatar
    Jan 2011
    Hepburn Springs,Victoria
    98
    Default 504 noisey waterpump
    I'm curious as to what is the cause of a 504 waterpump noise (pretty sure this is the problem area) No apparent play in the bearing,just a worsening noise at lower revs...a clunking sound.
    I'm on the road at the moment,will order a new one today.
    Advice appreciated.
    Cheers.
    Pughead
    tweed heads
    1,483
    Is it overheating , the noise could be the welch plug on the head behind the pump, has fallen out and and rattling on the impeller ,pugs
    Beano likes this.
    Fellow Frogger! Dano's Avatar
    Apr 2012
    961
    Could be one of two things.
    The Welsh plug within the head behind the the pump impeller, has come loose and rubbing/grinding on the impeller.Or, the thermo fan coupling is letting go. From experience, I think you will find it is the first suggestion.
    Dano
    Quote Originally Posted by Pughead2 View Post
    Advice appreciated.
    Cheers.
    Pughead
    Jan 2011
    98
    It's not over heating and thermo fan seems intact.Appreciate the comments.The welsh plug issue would seem to explain why the noise is not apparent under highway speeds....the coolant pressure of the pump is keeping the plug off the impeller ???
    COL
    COL is online now
    A110 COL's Avatar
    Van Diemen's Land
    3,974
    I would remove the drive belt/s for the water pump, fan, alternator, etc and spin each item by hand, if there is a bearing issue you will hear and feel it.
    Beano and Wildebeest like this.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    Jan 2011
    98
    Have done so,fan and pump feels fine,no bearing roughness or play.
    COL
    COL is online now
    A110 COL's Avatar
    Van Diemen's Land
    3,974
    Have you done the same with the alternator etc?
    Regards Col
    1973 Alpine A110
    Jan 2011
    98
    Yes,alternator is sound, thanks.
    tweed heads
    1,483
    Have a look and see if the thermostat is intact ,i checked mine recently only to find the guts of it was missing ,probably removed by previous owner ,im trying to visualize the coolant passages and it seems possible that bits of the thermostat could end up in the pump, although i have never heard of this happening before ,when the welch plug went on mine it was making a funny,metallic jangling noise ,when it was running but i couldnt feel any thing spinning the pump with the belt off ,although my son had to nurse it back from coffs with it getting pretty hot ,have just replaced my radiator so that could have been a contributing factor ,pugs
    SWOTR
    3,472
    I'm not sure that bits of thermostat would end up in the pumps impeller housing. The thermostat is located in the pumps outlet hose which goes to the radiator. Any thermostat bits would be more than likely be trapped in the radiator top tank.
    Having said that, if the thermostat is old, I'd install a new one as a matter of course. Faulty thermostat = probable cooked engine.
    Perth Western Australia
    2,674
    Poor contact of carbon brush, allowing fan clutch to intermittently engage. Remove brush and stretch the spring until a replacement is found.
    Oct 2003
    canberra
    831
    agree carbon brush not making contact ,
    you can lock the fan by tightening the 3 10mm nuts on front of the fan clutch
    Our most Southern Member (Tas)
    273
    David
    Have you left Cooktown ?
    (New location on post ? )
