Catalytic Converter issues Peugeot 406 3.0 V6 Coupe XFX motor
Results 1 to 7 of 7
    Aug 2018
    5
    Default Catalytic Converter issues Peugeot 406 3.0 V6 Coupe XFX motor
    Hi all,
    The good old check engine light is on and the scanner at my mechanics says BOTH catalytic converters need replacing. Its the later V6 (2001 model) and I'm hoping a member has a less expensive solution than the $2000 my mechanic is quoting me.
    Jul 2013
    Newcastle/ central coast
    2,222
    There are a few exhaust shops that sell 02 sensor trickers that stop the lower sensors seeing the cat inefficiency
    Garage C5 X7 3008 XTE
    Fix it right the first time
    Garage C5 X7 4008
    10,127
    Wouldn't this have a pre-cat on each bank plus a main cat further back. Is it suggesting cat ageing faults on both pre-cats or something else? The main cat can block up and strangle the car, so consider that. You can fit an aftermarket unit for something like $600, but the exhaust note will change a little. The factory part would be best if possible.
    Are you using 95 or better fuel???
    Jul 2013
    2,222
    Unfortunately the cats are no longer available and the pre cats are very 406 specific these are the ones that are monitored
    Garage C5 X7 4008
    Aug 2018
    5
    According to the mechanic both the pre cats....always use 95 ron but I guess at 170,000ks cats do have a life expiry...wasn't aware there was another cat further down the exhaust so will check that out...thanks
    Aug 2018
    5
    So tricking the sensors....would that not cause engine issues? If there is no sensor on the main cat maybe an aftermarket or performance replacement (I've read the cats strangle a bit of performance from the XFX motor) Any clues on where to get the precats at a fair price?
    Jul 2013
    2,222
    There are aftermarket options but sometimes those will still give you the inefficiency codes anyway pm me for more info, the downstream sensor only checks the cats and doesn’t change fuel trims. A front and rear cat is around 1000 delivered ,genuine when you could buy them about 2k each
    Garage C5 X7 4008
