How do i find out what model of engine in have. 2005 307
  • 1 Post By David S
Thread: How do i find out what model of engine in have. 2005 307
    Feb 2019
    Lismore, NSW
    2
    Default How do i find out what model of engine in have. 2005 307
    need to try and find a replacement turbo but everywhere i look has a very wide range of engine models.
    normally there is something in the engine number however i can not see anything that matchs between the options listed and my engine number
    i also can not see a plate anywhere that has it on it
    my engine number in case i missed something is PSA9HZ10JB310005850'
    Thanks all
    10,127
    9HZ tells you it's a type of DV6 HDi.
    If you look on the turbo ID plate it should be a Garret GT1544V and will have some other numbers too. the 96.. number would be the Pug/Citroen reference and it will probably have a number starting with 5. This turbo was also used in various Citroen, Ford and others.
    Suggest you read through these too as you may need to do more than just replace the turbo:
    Dealing with a failed DV6 turbo - links to other threads in included in this one:
    Getting to know my new 07 C4 HDi - with your help please
    DV6 1.6HDi lube/care: 1.6 HDI Oil Lubrication and Maintenance. Avoiding Problems.
    dmccurtayne likes this.
    Jul 2013
    Newcastle/ central coast
    2,222
    Cant read the links but make sure you replace the oil pickup oil feed pipe and banjo bolts if you donít youíll have a bad day
    Garage C5 X7 3008 XTE
    Fix it right the first time
    Garage C5 X7 4008
    Feb 2019
    Lismore, NSW
    2
    thanks mate, very helpfull
