Replacement of Aux serpentine belt on 2008 Peugeot 308 hatch
    Jan 2019
    Newcastle/Australia
    8
    Default Replacement of Aux serpentine belt on 2008 Peugeot 308 hatch
    Replacement of Aux serpentine belt on 2008 Peugeot 308 hatch with petrol THP engine.
    As the car is getting a bit old , I thought it be a good idea also to change the Auxilliary drive belt that drives the alternator and air conditioner (and engine water pump).
    As a clue to wether the belt has been changed before, I'm told that the cars were fitted with Dayco brand belts out of the factory.
    see attached photos.
    Use a 30mm socket and rotate the spring loaded adjuster anticlockwise until the locking pin can be engaged.
    Locate the "tab" on the water pump drive tensioner and pull it out.
    It is just held in by a sealing O-ring. Pull it out (like a tape measure) about 25mm, it will be loose.
    And then pull it out another 50-75mm under moderate tension and it will release the tension on the water pump drive wheel. (unconventional way to drive a water pump)
    You can now remove the belt from the crankshaft pulley.
    The belt was a Gates 6PK095, a direct replacement for the original 10 year old Dayco.
    Replace the belt, release the belt tensioning pulley (with the 30mm socket)
    Insert the water pump drive "tab" fully, and start the engine.
    I heard an unusual noise (but not alarming) that disappeared after about 2 minutes, that I assume was the water pump tensioner doing its job.
    All good.
    Jul 2013
    Newcastle/ central coast
    2,117
    Just make sure that belt has a rough back side it needs to drive the water pump
    Garage C5 X7 3008 XTE
    Fix it right the first time
    Garage C5 X7 4008
    Jan 2019
    Newcastle/Australia
    8
    That is a wierd (French) way to drive a water pump.
    I havent seen that before.
    9,016
    It might be a German idea. The original EP6 engine is a joint design. The aim is to save wasting energy and fuel when water circulation isn't wanted. The chain drives only the camshafts.
