Rear Shocks OK for S1 205GTi ?
  • 1 Post By VMX
Thread: Rear Shocks OK for S1 205GTi ?
    VMX
    VMX is offline
    Tadpole VMX's Avatar
    Sep 2017
    7
    Default Rear Shocks OK for S1 205GTi ?
    Happy New Year.
    I have of a pair of Bilstein B4 BNE-6814 as recommended here...
    https://www.kamracing.co.uk/manufact...oad-setup.html
    They are longer than standard...their extended length eye to eye is 343mm and their compressed length is ~262mm
    Standard shock length would appear to be 322mm.
    S1 205 GTi how to raise rear suspension to stock height ?
    TIA.
    9,276
    Bin them, originals will be much better. Length won't be a problem though.
    VMX
    VMX is offline
    Sep 2017
    7
    I hear you Graham and thank you... sadly I don't have originals. They were TEC ? [brand] with no oil left inside.
    Thanks also for confirming length will be OK. Since posting I've removed the shock and loaded the boot with everything heavy I can find. The rubber buffer is nearly touching the arm and the bolt holes are 270mm.
    VMX
    VMX is offline
    Sep 2017
    7
    oops, what I meant was my car had TEC shocks and they were stuffed.
    On the upside, fitting the bilsteins and some new tyres means I can get rego, and a neglected GTi hits the road again!!
    FIVEDOOR likes this.
