Turbo wastegate actuator
Results 1 to 10 of 10
    AAA
    AAA is offline
    Member AAA's Avatar
    Nov 2016
    Australia
    67
    Default Turbo wastegate actuator
    Hi , I just replace my catalytic converter and I notice the wastegate actuator door half open.
    Is this suppose to be closed when engine is off ??? IMG_1546563429.121646.jpgIMG_1546563451.888667.jpg
    Fellow Frogger! dmccurtayne's Avatar
    Jul 2013
    Newcastle/ central coast
    903
    You may have excessive play in the shaft where the valve pivots in the housing unfortunately you may need a turbo.
    Yes it does open when off but looks quite loose put vac to it and see if it seals
    Garage C5 X7 3008 XTE
    Fix it right the first time
    Fellow Frogger! gromzx's Avatar
    May 2011
    melborne
    350
    I was under the impression, newer engines with electronic boost control, operate in this way as a fail safe. As in, the actuator must be powered up to close the waste gate.
    This is the opposite of a conventional system where the spring holds the gate closed until pressure is applied (or enough pressure in a purely mechanical system) to the actuator.
    Please correct me if I am wrong.
    Jul 2013
    903
    Vacuum is controlled by a solenoid so the valve opens when vacuum is lost so I guess double fail safe loose electric control or loose vacuum and turbo is vented but these are common to leak because the plate becomes of set
    AAA
    AAA is offline
    Member AAA's Avatar
    Nov 2016
    Australia
    67
    This photo comes from my Peugeot 207 gti 2007 model.
    I notice Iím loosing boost when driving specially going up hill.
    Do u think I need to replace my he wastegate actuator or tighten it to close it.
    AAA
    AAA is offline
    Member AAA's Avatar
    Nov 2016
    Australia
    67
    What happen if it doesnít seal will need to replace ???
    AAA
    AAA is offline
    Member AAA's Avatar
    Nov 2016
    Australia
    67
    Wastegate actuator??
    Jul 2013
    903
    The problem if it is that leaking , is the pivot point, if you look where that valve hinges itís in the housing of the turbo once that wears its new turbo unfortunately you need to confirm that when you put vacuum to the diaphragm and it pulls that rod it seals tight some times the dump valves fail but that wastegate looks pretty worn in the photo
    AAA
    AAA is offline
    Member AAA's Avatar
    Nov 2016
    Australia
    67
    Ok will check it out.
    AAA
    AAA is offline
    Member AAA's Avatar
    Nov 2016
    Australia
    67
    Thank you everyone
