Will a 206 gearbox fit a 306?
Results 1 to 15 of 15
Like Tree4Likes
  • 1 Post By Brett
  • 1 Post By cav91
  • 2 Post By Demannu
Thread: Will a 206 gearbox fit a 306?
    Member Ginch's Avatar
    Feb 2012
    Ballarat VIC
    44
    Default Will a 206 gearbox fit a 306?
    Hi all. I find myself having to replace the gearbox in my 2000 model 306 XSI 2 litre. Very very soon by the sound of it!!
    Having trouble locating one in Victoria... mainly because the wreckers are closed over the Xmas period.
    So I see there is one available in Sunshine from a 206 (I know they are open because I spoke to the guy about a 306 gearbox they had on ebay but then withdrew the ad because they couldn't find it!! ) -
    Peugeot 206 GTi 2004 model 5 SPEED MANUAL GEAR BOX to suit a 2.0 Litre DOHC 4 cylinder engine in good working order with a low 71,720 kms on the odometer.
    Engine number Prefix is EW10J4.
    https://www.ebay.com.au/itm/PEUGEOT-...d=191579252936
    My engine is a XU104JR, does anyone know about the compatibility between them? Thanks, Michael
    Fellow Frogger! Brett's Avatar
    Nov 2001
    613
    206 has a hydraulic actuated clutch, 306 has a cable clutch
    Ginch likes this.
    Bathurst______2 57.22 Sandown_______1 35.29
    Mallala_______1 22.90 Phillip Island____1 56.41
    Winton_______1.43.90 Collingrove_______38.08
    The Bend_____2 21.96
    https://www.facebook.com/FrogstompRacing/
    http://www.harlandeng.com.au
    IWS
    IWS is offline
    1000+ Posts IWS's Avatar
    Feb 2005
    Hawthorn East, Vic.
    1,269
    Ginch,
    Have you tried French Connection in Airport West? (They sponsor this forum).
    Ian.
    Feb 2012
    Ballarat VIC
    44
    Thanks guys. Yes I have (they were the first I tried and have bought from them previously) but no answer, I assume they're on holidays still.
    6,053
    Ginch, the owner David Cavanagh is also member here; you might be able to PM him.
    2003 PEUGEOT 206 GTi
    1000+ Posts cav91's Avatar
    Sunbury, VIC
    2,255
    I'm pretty confident we'd have one. (French connection) 206 will not work for you. We reopen on the 7th (amongst my dismay, I'm currently in a caravan park in victor harbor).
    Sent from my SM-G930F using aussiefrogs mobile app
    Dano likes this.
    406 D8 V6 manual
    Feb 2012
    Ballarat VIC
    44
    Thanks Stuey, and thanks David! No doubt Victor Harbour is absolutely crazy and you'll be happy to get back to work for a bit of peace and quiet!
    I'll call on Monday, have a safe trip.
    Sunbury, VIC
    2,255
    Quote Originally Posted by Ginch View Post
    I'm actually David's son. I'm Chris, but we work together!
    406 D8 V6 manual
    Feb 2012
    Ballarat VIC
    44
    Sorry Chris!
    Dec 2002
    2,502
    I've got a BE3 gearbox to suit XU engine that you can have for nothing. Condition unknown (been in the shed for years), but I don't think I would have kept it if it had a problem.
    Dano and Ginch like this.
    Scotty
    Melbourne - Dandenong Ranges
    2014 Peugeot RCZ - 'Remy'
    8,979
    You may need to change the bell housing over to a pull type clutch.
    Feb 2012
    Ballarat VIC
    44
    Thanks Demannu! That is quite close to my budget as it happens!
    Mine has the electronic type speedo sensor, do you happen to know if that's a straightforward swap? Assuming the one on yours is the mechanical kind?
    I'll take you up on your very kind offer if the speedo can be made to work... I've sent you a private message.
    Cheers Graham, sounds like that may be an option if necessary.
    8,979
    Sorry, just need to change the clutch shaft not the whole bell housing.
    Jul 2004
    799
    As already posted a be4 (206) bell housing will not suit an Xu motor due to the ew motor sitting at a different angle than the Xu. From memory they do actually bolt up but it will put the diff in the wrong spot.
    You can however swap bell housings over from be3 to 4- it requires you to dissassemble the whole casing though.
    The speed sensor will swap over from all Be gearboxes.
    Finally you can also purchase a bracket+fork from psa to convert hydraulic clutch be4 gearboxes to cable. Lhd 206 gti180 and some smaller psa vans had cable be4 boxes.
    I would be looking for the serial code on your gearbox and searching with that. It should be something like 20dp** ie- 20dp10. Usually on the front of the gearbox.
    Feb 2012
    Ballarat VIC
    44
    Appreciate the info James!
