407 2.7 Diesel Coupe Wonít Start
Results 1 to 10 of 10
  • 1 Post By Coupe407
Thread: 407 2.7 Diesel Coupe Wonít Start
    Sep 2017
    Alstonville
    8
    Default 407 2.7 Diesel Coupe Wonít Start
    Hi,
    Iím hoping for some advice re my 407 Coupe which has starting issues.
    Drove for a few hours on the highway on Chrissy eve and about 10 ks from home I notice a slight miss and a brief moment of roughness during acceleration. No loss of power. Anyway got home ok and the pug sounded normal when I stopped, no dash lights on.
    The next morning the Economy Mode was on and the car would turnover, try to start but not start.
    After a little research I charged the battery just in case a light was on overnight.
    The car now has a window partially down and due to economy mode it wonít go up. Economy Mode wonít go away until the car starts and runs for a while! What the!!!! Who at Peugeot thought that was a good idea!
    Anyway I managed to start it twice (just) but it ran like a hairy goat. The fact that it started ruled out some elecrical/fuse issues, which is a plus. I figure it is fuel related, fuel pump, filter, pressure regulator .... any ideas on where to start?
    Thanks,
    Wayne
    Jul 2013
    Newcastle/ central coast
    2,125
    Starter motor can turn to slow on dt17s and cause this sounding problem you can over ride the eco mode on the windows by locking the car and holding the remote lock button down until the windows close trust me you donít want not to have economy mode.
    What area are you in.
    Garage C5 X7 3008 XTE
    Fix it right the first time
    Garage C5 X7 4008
    Jul 2013
    2,125
    But miss once hot donít know Iíd be checking the fuel itself
    Garage C5 X7 4008
    Sep 2017
    Alstonville
    8
    Hi,
    The starter seems to spin the motor well so not leaning towards a starter issue.
    I did try the door lock button but it doesn’t seem to work on my car :-/
    Sep 2017
    Alstonville
    8
    I fuelled about 70-80 k before ai noticed the miss so was wondering if I got some bad fuel. It was at a big BP service centre so unlikely but possible. I will change the fuel filter when I can source one.
    Jul 2013
    2,125
    Definitely not petrol? Similar symptoms
    Garage C5 X7 4008
    9,031
    Economy mode protects the computers. As dmccurtayne said, you need it.
    If you think you have bad fuel, it is could be water. The filter has a drain for this purpose, so run some into a glass jar and see. It should be done at service anyway.
    Sep 2017
    Alstonville
    8
    Ok will check that. Thanks
    9,982
    Load test the battery. You may have charged it, but if it's old (i.e. 3+), it might have only accepted a weak charge.
    Sep 2017
    Alstonville
    8
    Problem solved .... new filter did the trick. Thanks for the suggestions.
    BIGRR likes this.
