205 engines
Results 1 to 14 of 14
Thread: 205 engines
    Member jamin's Avatar
    71
    Icon5 205 engines
    Hey guys ,
    What is the difference between the 205 GTI S1-2 UK and Australian engines.
    The Aus engines are 75kw and UK engines are about 100kw, what did they do to the Aus spec engine to detune it?
    Jamin
    Ipswich, Queensland.
    1,911
    Different head, poorer porting, less compression. All the things you need to do to kill an engines' Hp.
    '56 Renault 750 (16TS Power)
    '62 Renault Dauphine Gordini
    02 and 03 Renault Clios 1.4L
    7,483
    Quote Originally Posted by alan moore
    Different cam too. The timing is really dull.
    1000+ Posts Dave's Avatar
    Apr 2001
    1,340
    To make a euro spec engine (minus cam) you need to get a series 1 block and a series 3 head. This gives more compression and larger valves. The series 3 cam is also better than the earlier one.
    Dave
    Member ozclio's Avatar
    Aug 2003
    57
    Why not just buy a late model (1992 - 1995) 405 s, sri 1.9 ltr engine and if necessary, gearbox. It is the 405 engine that the 205 uses isn't it? Thats what I would consider doing if my engine ever died. Probably more 405 wrecks out there that 205 gti wrecks?
    Trent.
    71
    Icon9
    Thanks guys.
    I've had my s2 for about 2 weeks, 1.5 of that it's been at Elliot Tune getting a new clutch, cv joints, tune, etc etc, Just got it back this morning
    It just needs a few bits and peices now and it should be sweet.
    I'll post some pics once I clean it on the weekend.
    I can't believe Peugeot went to all that trouble for us aussies, i'm touched. :p
    Our pertol wasn't a high enough rating, is that the reason?
    9,261
    Quote Originally Posted by jamin
    Thanks guys.
    No, we went to unleaded in 1986.
    The series three engine was a lot closer to the european specs because it used a more sophisicated fuel management system.
    I believe the mono point system fitted to my SI to be better than the Bosch L system fitted to the series 1 and 2 GTIs. At least it is digital and has fully electronic ignition.
    Graham Wallis
    1000+ Posts Luca's Avatar
    Mar 2003
    1,335
    Thanks guys.
    J - You can get the S1 head cooking if you want.. i ended up getting some work done to mine that has made it pretty hot. Let me know if you want some more info...
    7,483
    Quote Originally Posted by Luca
    Dave is right. The 75kW DFZ block, as fitted to early 205's and 405's, has smaller piston dishes than the later 90kW DKZ(?) block. The chamber in a DKZ engine is 34cc compared to 49cc in the DFZ. So putting the two together produces good compression, around 10.5:1.
    Early 1.9L GTi's in the UK also had a version of the L-Jetronic, but without the lamda sensor.
    Apr 2001
    1,340
    Thats right Peter, the DFZ block, with the DKZ head is the combination referred to. From memory the DKZ head was 38cm3.
    How much power did you end up getting out of your 205 8 valve engine?
    Dave
    Mar 2003
    1,335
    That's all true but if u can't find an SI head your up shit creek.
    That's why I said you can still get decent gains out of the DFZ head with the right work done.
    Fellow Frogger! AU-YT's Avatar
    Apr 2003
    229
    Default 205 Cti
    From what I can find Australia got the US spec CTI engine.
    The head block I used was a Jaz head on a S1 block and pistons as a start.
    Actually didnt mean to, Just managed to buy a brand new one (no more left sorry) from P504 services. Thinking it was only a S1 head It now has 2mm O/S valves inlet and exhaust and I think a Grp N cam plus lots of other fiddles different computer etc description MUCH better and torque! any one have a 6 speed gearbox?
    1000+ Posts parry's Avatar
    Sydney Australia
    1,329
    My S1 engine is now close to 100kw thanks to Peter T and Adrian W. It goes like the clappers!!!!
    90 205 Gti Cherry Red(Track Car)
    2009 207gti
    1985 505gti (Shitbox Rally) Sold
    PBs:
    Oran Park: 1:27:9
    Wakefield: 1:05.6 (July 2015)
    Eastern Creek: 1:54 (8v) 1:48 (16V)
    Mt Huntley: 34.44 (2004 stock 205)
    Ringwood: 35.06 (30/10/2005)
    Winton: 1:33.6 (2017)
    7,483
    Quote Originally Posted by parry
    Yes, I'll need to clip your wings tomorrow. Hopefully I've now got all the bugs out of mine and time to extract my digit!
