306 Cabrio 1998 Phase 2, 2 litre- odometer has died, cause & remedy?
Results 1 to 15 of 15
    Auckland, New Zealand
    106
    Default 306 Cabrio 1998 Phase 2, 2 litre- odometer has died, cause & remedy?
    My 98 Phase 2 306 Cabrio has completely lost its digital odometer readout, happened suddenly. Car has done 180,000 km approx.
    What are the most likely causes and remedies. Is the speedometer removeable from the cluster individually or does one need to replace the whole instrument cluster if the odometer is non repairable.
    Any help offered would be much appreciated306 Cabrio 1998 Phase 2, 2 litre- odometer has died, cause & remedy?-p1090785.jpgClick image for larger version.
    Jul 2013
    Newcastle/ central coast
    1,485
    Normally these just blow the globe behind the lcd on the odo easily replace t10 from memory pointing up
    Garage C5 X7 3008 XTE
    Gone but not forgotten 206 GTI 180 306 XR SED 405 MI16 x2 505 GR xzara VTS 406 SV 206 XT Berlingo 2011 (best car ever) 306 HDI 307 XSE HDI touring
    Fix it right the first time
    1,608
    If its stopped suddenly then check the gearbox sensor, $20 fix. Mind you if the tacho is working and the odometer is not or vice versa then this indicates this sender is working and you are lookign at a dry joint in the instrument cluster.
    Good luck, ask away
    307 HDi wagon
    407 HDi wagon
    Jul 2013
    1,485
    What does the tacho have to do with the odo ?
    1,608
    They are electrically connected in the cluster, or am I mistaken?
    My diesel 306 sedan has a bad sender, the tacho drops but the odometer does not. So as you say its backlight or dry joints in the led display.?
    Can't be, if the sender is not working then neither works, if one is working and the other not, then its cluster related?
    307 HDi wagon
    407 HDi wagon
    Jul 2013
    1,485
    The tacho comes from the engine speed sensor the speedo and the odo comes from the diff sensor/gearbox output or wheel speed sensor in later cars
    1,608
    Silly me, of course they do, the speed sensor will kill the odometer or dry joints the display then.
    307 HDi wagon
    407 HDi wagon
    106
    Thanks everyone for that feedback, I guess I need to access the rear of the cluster to check the bulb behind the lcd & replace that. Dp Pug dealers supply a bulb or can it be bought from an electronic component store?
    1,608
    Get onto ebay and get your self leds to suite, the only downside is dimming? Many places sell bulbs.
    307 HDi wagon
    407 HDi wagon
    Jul 2013
    1,485
    Jaycar repco the original ones lasted 20 years they will be fine
    1,608
    The odometer display is LED no backlight they are active light emitters. If they die suddenly its going to be electronic failure, this might be repairable but globes will not be the answer.
    307 HDi wagon
    407 HDi wagon
    Jul 2013
    1,485
    Are you sure there cowboy
    1,608
    I hope so, clear head after a day at work and having read this carefully enough and having driven my 2002 it is led digits. Prepared to be challenged, far too often it seems!
    307 HDi wagon
    407 HDi wagon
    Dec 2002
    2,507
    Quote Originally Posted by Matthew View Post
    I think you'll find it's a backlit LCD.....
    Scotty
    Melbourne - Dandenong Ranges
    2014 Peugeot RCZ - 'Remy'
    1,608
    Backlit LCD OK, buy the bulbs and fix it then makes life simpler.
    307 HDi wagon
    407 HDi wagon
