Buying a second hand motor
Results 1 to 16 of 16
Like Tree3Likes
  • 1 Post By David Cavanagh
  • 2 Post By SLC206
Thread: Buying a second hand motor
    Tadpole 207ccRipper's Avatar
    Aug 2018
    Victoria
    12
    Default Buying a second hand motor
    How do these wreckers know if there motor is compatible with my car, they always ask for the VIN, they seem to have some program or web site which sells them if the VIN’s are compatible
    8,316
    Letters 6-7-8 of the VIN describe the engine type. That's the main thing. The last group of numbers gives the position in the production if there are minor changes. They also have the same access to the Peugeot service part numbers online we all have.
    Jan 2014
    Coffs Harbour, NSW Australia
    277
    Is this thread about a motor or an engine? There is a big difference as a friend of mine found out in the early days of his apprenticeship. He removed the engine, but the boss had wanted the motor out and waited till he finished so the lad would learn the difference and never forget it. Wound up being a very mechanic.
    Cheers.
    Feb 2001
    Romsey, Victoria, Australia
    4,747
    Quote Originally Posted by 207ccRipper View Post
    We have a saying that Peugeot never built the same car twice so therefore the VIN is the only way of telling which parts are compatible with your car.
    We go onto the Peugeot website and that tells us more about your car than you'll ever know.
    David Cavanagh
    03 9338 8191 or 03 93354008
    34 KING St
    AIRPORT WEST
    VIC 3042
    [email protected]
    8,316
    Heaven help Kelpiebat's boss if he reads the French manuals- the whole thing there is a moteur.
    The words are from Latin via French - movere - to move.; perfect tense motus. Ingenium - talent, ability. Motor came to English with the sense of initiating movement or action, while Engine became a contrivance. A mediaeval engineer built military devices.
    The two words have now essentially merged.
    4,305
    Quote Originally Posted by kelpiebat View Post
    Cheers.
    I remember the days when you could buy a replacement or reconditioned motor - described as being either a long motor or a short motor, based on what peripherals it came with essentially. But I'm intrigued - for the purposes of your story, what is the difference between an engine and a motor in this context?
    KB
    Feb 2001
    4,747
    A motor is electrical as in wiper motor, starter motor etc.
    David Cavanagh
    34 KING St
    AIRPORT WEST
    VIC 3042
    [email protected]
    4,305
    Makes sense. But in kelpiebat's example, the boss clearly didn't specify which motor he wanted removed if that's the case. So he brought it on himself to some extent.
    Why then did the long and short MOTOR definition become industry standard if it was indeed the ENGINE?
    KB
    Feb 2001
    4,747
    That I don't know but I use to work with an old mechanic who would tell us off if we called an engine a motor so just to annoy him we'd call starter motors starting engines and wiping engines and he'd get annoyed.
    hypermiler likes this.
    David Cavanagh
    34 KING St
    AIRPORT WEST
    VIC 3042
    [email protected]
    8,348
    I'm just about to buy a new motor for my boat. It is not a motor boat or even an engine boat , but a sail boat...
    Motor or engine, the term stink boat still fits.
    Have we all got it wrong, am I actually buying an outboard engine????
    Jo
    8,633
    Jo
    Dunno.
    Will you take it on board ?
    ACHTUNG ALLES LOOKENPEEPERS
    892
    Jo
    Depends I guess on whether your boat will be enginised or motorised after you install it.
    1984 505 Executive Auto
    206 GTi 180 - '804 Cat Cams, Jenvey DBW 48mm ITB's, Emtron KV8 ECU, HP Electronik PDM, AIM MXS Dash, Custom Wiring Harness. AST Camber Tops & Coilovers, -2deg camber hubs by Frogstomp Racing, 24mm Torsion Bars, AP Racing brakes, PeugeotSport Baffled Sump, Oil cooler, Quaife LSD, E85.
    Sandown - 1:31.5
    Winton - 1:40.2
    Wakefield - 1:13.5
    Phillip Island - 1:55.9
    Previously, 2x 504 Wagon, 505 Wagon, 505 STi, 405.
    Jan 2014
    277
    As we all know advertisers use a lot of dictionary licence to sell whatever crap they want to. And by so doing they subvert the correct language. Mr google says that the intermixing of engine and motor occurred when the first internal engines were referred to as motors to identify them as being different from steam engines which were very popular at the time. Since then the terminology has generally adjusted to an engine combusting its own fuel whilst a motor relies upon an external source of power.
    I'll rest my case on the non-existence of the term, electric engine. Cheers and happy Peuging.
    8,348
    Long live the motor car!!!!
    Sep 2003
    North Parramatta
    3,975
    With an internal combustion engine?
    BIGRR and David Cavanagh like this.
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
    Lavers Hill
    310
    Actually an engine is a type of motor. (A motor is a source of motive power.)
