Loud screeching noise in a 308cc engine.
Results 1 to 10 of 10
Like Tree2Likes
  • 1 Post By Nagaman
  • 1 Post By dmccurtayne
Thread: Loud screeching noise in a 308cc engine.
    Tadpole 207ccRipper's Avatar
    Aug 2018
    Victoria
    12
    Default Loud screeching noise in a 308cc engine.
    I have a 2009 308cc turbo in the morning at start up it produces a loud screeching sound I feel itís coming from the high pressure fuel pump but not sure. Anyway when it reaches pressure the noise slowly fades away. Kind of puzzled the motors runs fine, plenty of powers and the noise disappears once all is warm.
    Thinking of swapping out the fuel pump.
    Any clues guys.
    Regards
    Aug 2015
    Nagambie
    953
    Quote Originally Posted by 207ccRipper View Post
    Any clues guys.
    Regards
    ĎFan beltí / power steering belt a tad loose perhaps. As it heats up by slipping it would probably fade away.
    Sent from my iPad using Tapatalk
    207ccRipper likes this.
    Jul 2013
    Newcastle/ central coast
    1,086
    Vacuum pump stop driving it itís going to lock up and shit the cam
    Aug 2018
    Victoria
    12
    Not the fan belt just replaced it. All good thanks for the suggestion
    Aug 2018
    Victoria
    12
    Hmm vacuum pump , I have already pulled it apart looks fine plenty of oil inside to lubrication. Thanks for the idea though.
    Jul 2013
    1,086
    Try swapping one also sometimes the pcvs are noisy try starting it with the oil cap off if you have a code clearer
    Aug 2018
    Victoria
    12
    Ok Iíll give it a go. I have daigbox and PP2000. Strange one ah. I have had the car for a couple of months and when I went to see it it was already warm and running now I know why.
    Aug 2018
    Victoria
    12
    When the it gives a psst noise as the pressure releases if you get close to it you can hear it, when it does that the screech seems to fade away. Hmm
    1000+ Posts driven's Avatar
    Apr 2005
    1,298
    Get a long metal rod. Poke this down into the engine at each component in turn.
    Hold your ear to the rod
    You will quickly locate which component is causing the screeching
    May be pulley
    New belt has stretch da bit and is loose
    Aug 2015
    Nagambie
    953
    I use a piece of hose and use it like a stethoscope for noise location.
