Vacuum Pump and Secondary Valve
    Mym
    Mym is offline
    Jun 2012
    Mount Eliza
    29
    Default Vacuum Pump and Secondary Valve
    Hi there! Our Peugeot 307 (2005) has lately shown the Anti Pollution warning light plus the Engine Warning Light.
    Went to the mechanic today and the fault is P0410 which apparently indicates we need a new Vacuum Pump and Secondary Valve
    They indicated that (1) it may be in excess of $1500 for the part and (2) these parts are hard to come by...
    so they have promised to let me know once they confirm availability and cost.
    Being a bit of sceptic, I thought I would ask on this forum to see if the information I have been given is accurate, and if there is a some other solution.
    Thank you for taking the time to read this.
    8,496
    The code is for the secondary air injection. They aren't as expensive as estimated though. Online retailers have them. You might also try EAI.
    It is a common fault as these engines age.
    Jul 2013
    Newcastle/ central coast
    1,649
    It could also be a split pipe to the head from the pump , blocked exhaust holes even blown fuse
    Mym
    Mym is offline
    Jun 2012
    Mount Eliza
    29
    Thank you so much, appreciate your help. Looks like it some investigative work is in order.
    Jan 2014
    Coffs Harbour, NSW Australia
    299
    Hi Mym, Which engine is in your car. I have 2 stat write off 307 shading some lawn.
