Well chaps, I guess it had to happen sooner or later....a heater core leak.
I was vacuuming out the car today and noticed a wet slimy patch in the
passenger footwell carpet.
After placing some toilet paper there to absorb it, I took a sniff and sure enough
coolant!....damn bugger and blast!
OK...where was it coming from??
Obviously I will have to do a pressure test to determine if there is a leak and
start tracking it down.
Using a bright torch, I scoured the engine bay and underneath....no sign of a leak.
So, it's obviously internal and is leaking some where higher and dribbling down under the carpet.
My guess is either one of the heater hoses or the matrix itself.
After reading the trusty Haynes manual, it wasn't really clear on the fact whether the
matrix/core is accessible from inside the car or from the engine bay side.
Any help with this will be appreciated.
This is the first cooling system problem I have experienced in 15 years ownership
and 187,000klm.
